0 members (),
93
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#81377 08/13/2007 3:25 PM | Joined: Jun 2007 Posts: 101 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2007 Posts: 101 | I need to remove the bellhousing to attatch my engine to the stand. There are to upper bolts on that I have found but the lower bolts I haven't. What is the procedure to remove the bell housing.
Thanks | | |
#81378 08/13/2007 4:18 PM | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | If your engine is a 216 or 235 you have to remove the clutch and the flywheel to get to the other bolts that hold the bellhousing on. Also remove the tin plate on the front of the bellhousing and the starter. Fred
#81379 08/13/2007 4:56 PM | Joined: Jul 2005 Posts: 308 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 308 | Fred is correct, I just went through that with a 235.
Ed | | |
#81380 08/14/2007 5:25 PM | Joined: Jun 2007 Posts: 101 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2007 Posts: 101 | Its a 235. I will try to get it done this weekend. Thanks for the help. | | |
