5 members (KEVINSKI, Shaffer's1950, Rusted Nut, klhansen, lumbersawyer), 125 guests, and 3 robots.
Topics128,096
Posts1,056,487
Members48,444
#813011 01/04/2012 2:57 AM
7
7 Offline
I have a 62 chevy two ton truck a guy is trying to sell me and says it has a 350 engine in it. If it is a 350 it is not stock right? It also has a 5 speed transmission in it. What v8 engines came out in these trucks?
3B Offline
Hy 79broncoowner, everything below the eighty one series was either a 283 or a 327 as far as V8s are concerned, hope that helps.
7
7 Offline
Thanks I thought 283 or 327 was the right engine. I am going to look at the truck today maybe I can get some numbers off of the engine
It could also be a 348
7
7 Offline
I think it is a 350 that someone put in this truck.It has a rebuilt tag on the front of the engine. This is a complete truck with no bed and it is a c 60. What would this truck be worth without an engine. IT has a 5 speed transmission and a 2 speed rearend. The body is fair.
In the Spokane area a non running 62 c60 with a fair body would be worth scrap value.
Jason
1946 GMC COE
1967 Pontiac Lemans Convertible
http://s1275.photobucket.com/user/jrpontiac/library/?sort=3&page=1
79,
Why did the owner take the motor out...is the transmission bad?
Around here the scrap man will deduct about $30 per tire, so factor that in on your bid.
So, lets do some simple math...if the truck weighs about 5000 pounds (Cab and Chassis) per the book, less motor your at about 4500 pounds at $0.0875 per pound thats $393.75 less $180 for the six tires means it's worth about $213.75 scrap here in Maryland.
Your actual weight and scrap price may vary.
Hope this helps...
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
7
7 Offline
THe engine is still in the truck. What I meant was that somewere alone the line a 350 was installed in the truck. He said the engine was good but has not been run in about 3 years. I was going to buy the truck and pull the 350 then sell or scrap the rest. I hate to see it go to the scrap yard if someone could use so parts off of it.
OOPS, my bad, I misunderstood...
I'm happy your trying to save what you can, they don't make some of this stuff anymore.
Take care...
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
7
7 Offline
It might be hard to sell the big truck stuff but like you said they dont make a lot of it anymore. I might talk to the guy tommorow and find out some more about the truck
Let us know if you decide to part it out...
Mike B
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
7
7 Offline
I will let you know.
Crusing in the Passing Lane
Make sure and save the 5 speed, it might even be an OD. Probably some Clark or NP.
