4 members (66flea, Jon G, dt235sd, 1 invisible),
90
Mod | | | Forums66 Topics128,064 Posts1,055,860 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2010 Posts: 91 Shop Shark | | Shop Shark Joined: Jul 2010 Posts: 91 | Hello all. I recently bought a good-running 250 I-6 Chevy engine to power my '46 2-ton. I'm having a bear of a time identifying exactly what year the engine was made and what vehicle it originally came out of (for parts replacement). Anybody have a secret decoder ring for Chevrolet 6-bangers?
The block casting number is: 348675 (250ci between 1973 and 1976)
The numbers on the stamp-pad behind the distributor are:
F0624TAB = engine serial number. T4F728072 = engine "vin".
Thanks for any help.
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | As long as you know the year range of manufacturer, any parts within that range will fit that engine.
Drew
| | | | | Joined: Mar 2006 Posts: 319 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 319 | Engine serial number: F = Flint, MI 06 = June 24 = day of month TAB = C10,K10,C20,K20 http://www.73-87.com/7387info/engineid.htm (link to "TAB") Engine "VIN" T = not sure. Examples I've seen start with numbers. "1" is Chevrolet. 4 = year. (74' since you already know it is a 70's block) F = Flint, MI (place vehicle was assembled) 728072 = last 6 numbers of vehicle VIN repeated on the block. Hope this helps.
"Nothing astonishes men so much as common sense and plain dealing." - Ralph Waldo Emerson
| | | | | Joined: Jul 2010 Posts: 91 Shop Shark | | Shop Shark Joined: Jul 2010 Posts: 91 | Excellent! Exactly what I was hoping for. Great thing about this motor is it DOESN'T have the junk integrated cylinder head, but it DOES have the electronic HEI ignition (prob someone else's past upgrade but it works for me)! It's gonna be backed by a 700R4 automatic w/od to help tame the 6.17 rear gears.
Thank you very much.
