3 members (Hotrod Lincoln, Ponchogl, 1 invisible), 40 guests, and 3 robots.
Topics128,024
Posts1,055,395
Members48,422
#813596 01/05/2012 7:41 PM
I can't seam to find out how to adjust the lifters on my 65 283v8. I had to put new head gaskets on it. I did my 89 it was easy, but it also has hydraulic lifters. Any help or web site info would be great.
Thanks Brett
H Online: Content
All Chevy V8 hydraulic lifters are adjusted the same way- - - -get both valves closed on the base circle of the cam, take out the slack in the pushrod, and turn the ball stud nut another 3/4 -1 turn to compress the lifter slightly. Use the search function here to find "companion cylinder valve adjustment". The companion cylinders on a Chevy V8 are:
1 8 4 3
6 5 7 2
When #1 is "rocking", with the exhaust valve closing and the intake opening, #6 is on TDC of the compression stroke, ready to adjust. Follow the firing order, and all 16 valves can be adjusted in 2 turns of the engine.
Thanks Jerry, but my 65 has solid lifters? I'm not realy sure if this thing has ever been rebiult.
Can't seem to get the search to work either. I can't seam to find anything on valve adjustment. Brett
Would have been built w/ hyd.
If someone has changed cams w/ solid lifter type you would need to find the cam manufactures specs.
BC
1960 C60 pasture art
BC59 #813637 01/05/2012 10:10 PM
Thanks BC59, did'nt realize that they had hydraulic lifters.I should be able adjust like my newer Chevy 350.
H Online: Content
If you try to do a running adjustment, you'll make a horrendous mess, and the adjustment won't be right when you're done.
Thank you everyone, adjusting now and it's going great.
Brett
