| | | Forums66 Topics128,023 Posts1,055,365 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2010 Posts: 132 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 132 | I can't seam to find out how to adjust the lifters on my 65 283v8. I had to put new head gaskets on it. I did my 89 it was easy, but it also has hydraulic lifters. Any help or web site info would be great.
Thanks Brett | | | | | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | All Chevy V8 hydraulic lifters are adjusted the same way- - - -get both valves closed on the base circle of the cam, take out the slack in the pushrod, and turn the ball stud nut another 3/4 -1 turn to compress the lifter slightly. Use the search function here to find "companion cylinder valve adjustment". The companion cylinders on a Chevy V8 are:
1 8 4 3 6 5 7 2
When #1 is "rocking", with the exhaust valve closing and the intake opening, #6 is on TDC of the compression stroke, ready to adjust. Follow the firing order, and all 16 valves can be adjusted in 2 turns of the engine. Jerry
| | | | | Joined: Apr 2010 Posts: 132 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 132 | Thanks Jerry, but my 65 has solid lifters? I'm not realy sure if this thing has ever been rebiult. | | | | | Joined: Apr 2010 Posts: 132 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 132 | Can't seem to get the search to work either. I can't seam to find anything on valve adjustment. Brett
| | | | | Joined: Sep 2011 Posts: 1,451 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,451 | Thanks Jerry, but my 65 has solid lifters? I'm not realy sure if this thing has ever been rebiult. Would have been built w/ hyd. If someone has changed cams w/ solid lifter type you would need to find the cam manufactures specs.
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Apr 2010 Posts: 132 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 132 | Thanks BC59, did'nt realize that they had hydraulic lifters.I should be able adjust like my newer Chevy 350. | | | | | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | If you try to do a running adjustment, you'll make a horrendous mess, and the adjustment won't be right when you're done. Jerry
| | | | | Joined: Apr 2010 Posts: 132 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 132 | Thank you everyone, adjusting now and it's going great.
Brett | | |
