| | | Forums66 Topics128,179 Posts1,057,134 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 56 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 56 | Hello everyone, i am posting this to get some info on what hood i need for my truck. i have a 1962 chevy c10 that now needs a new hood. i was wondering if the 1960-66 years all have the same hood or was there changes in the size, mountings, or design. any help will be great. right now i'm not looking to buy just getting info. Thanks. -Andrew | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | 60-61 is one style, 62-66 is another style. | | | | | Joined: Aug 2010 Posts: 56 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 56 | Ok so then if i were to purchase one it wouldn't matter if i bought a 66 and placed it on my 1962. | | | | | Joined: Jun 2009 Posts: 331 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 331 | Nope, should fit just fine:) | | | | | Joined: Aug 2010 Posts: 56 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 56 | Thanks so much guys. -Andrew | | | | | Joined: Aug 2011 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 51 | The 60-61 Apache hood was different from the rest of the hoods wasn't it? | | | | | Joined: Oct 2009 Posts: 426 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 426 | Yes. The 1960 & 61 shared the same style hoods and the 62-66 shared the same style hoods. GMC had some different turn signal shapes over the chevy | | | | | Joined: Mar 2009 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 51 | I think latch is different on 60/61but dont hold me to it . | | | | | Joined: Oct 2009 Posts: 426 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 426 | I think latch is different on 60/61but dont hold me to it . Yup...the latch is different between the two hoods | | | | | Joined: Apr 2003 Posts: 942 'Bolter | | 'Bolter Joined: Apr 2003 Posts: 942 | I've even seen 2 different style Latches on '62 to '66 Hoods. Anytime I needed a Latch, I always stuck to the same type. I never verified if they would interchange or not.
'60-'72 Chev/GMC Fan GMC 9500 Fan Detroit Diesel Fan
| | | | | Joined: Dec 2008 Posts: 337 Shop Shark | | Shop Shark Joined: Dec 2008 Posts: 337 | To summarize – any 1960-66 Chevy or GMC hood will fit any 1960-66 Chevy or GMC pickup, Suburban, or School bus with the full length hood. Chevy and GMC hoods share essentially the same sheet metal except for the front section. Early Chevy hoods have twin pods while the GMC has an open screen in front. On the later style hood Chevys have a somewhat smooth front panel while the GMC’s have a stamped intake scoop. Both series of GMC hoods have unique parking lights that are not common to Chevys.
The 60-61 style hoods use a latch with the release handle pointing down, accessed in the gap between the hood and the grille support.
The 62-66 style latch release handle points toward the driver side of the truck and is accessed in the rectangular hole in the front of the hood.
The latch panel that bolts to the grille support is the same for 60-66 with either style hood.
