2 members (Otto Skorzeny, carbking), 125 guests, and 1 robot.
Topics128,050
Posts1,055,760
#811935 12/31/2011 7:16 PM
i tried search,nogo.could someone point me the direction,install&the source of.yes i looked at mr.SWEETS pics.just enough get me to thinking.thanks
Riding in the Passing Lane
What year? Are you putting on a new kit or used parts?
1972 Chevy c10 Cheyenne Super
my truck is a1954.i plan doing a junk yard serch. thanks
It looks like you are looking for the sway bar for your truck. An original sway bar on a 1952-1955 1/2 ton panel body truck should work fine on your 1954 1/2 ton truck.
Jim Carter sells the bushings set (and, he sometimes has a used sway bar set).
ODSS Lawman
ODSS Lawman
I found my sway bar on eBay then got the bushing kit as Tim mentions above. Its a fun easy project!!!
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
well i think ihave taking care of my heating problem,so i,m back reserching front sway bars.while at p/p notice there is an abundance of s10s.has anyone tried useing a swaybar off an s10? thanks again...front swaybar
CPP sells a sway bar kit that bolts in. It is VERY heavy duty (1 1/8 inch bar)
and uses same frame and chassis mounting points as a stock one. Comes with all Teflon bushings, hardware, U=bolts, and mounting brackets.
I think it's about 169 bucks.
squire
Most likely better than the stock one too.
