1 members (stoveboltgator), 218 guests, and 0 robots.
Topics128,048
Posts1,055,540
Members48,425
#812637 01/03/2012 1:05 AM
Have a 42-46 clamped rear fender to it and the tire sits way back in the fender opening was this common the pics that I have seen most of them look like the tire is pretty well center in the wheel opening.
wdombrowicki #812649 01/03/2012 1:32 AM
Wheels are not centered on stock trucks for whatever reason. A lot of guys ( me included ) slide the axle back to center the wheel in the opening. I am running a TH 350 Auto trans, and had the length available on the driveshaft spline.
1940 Chevy KC 1/2-Ton
Britcon #812659 01/03/2012 1:44 AM
Bruce is correct, but some trucks (and cars, too) seem to look fine, while others look like a butcher job. My truck looks OK, and I won't change it, but I have seen others I could not live with!!
Only the long gone engineers know why....... smile
1940 Chevy 1/2 ton pickup "KC"
A day without sunshine is like, well, ..... dark!
40casey #812679 01/03/2012 2:57 AM
I would need to move the axels foward about 3" does anyone know if that would be a problem.
wdombrowicki #812725 01/03/2012 5:06 AM
If your axle is that far aft I would suspect it is not stock. We need to identify what you have before we can identify problems. Post a link to pictures.
wdombrowicki #812932 01/03/2012 10:59 PM
Have pic here at photobucket on here.
wdombrowicki #812943 01/03/2012 11:34 PM
after reading this,i bwent out and measured my axel location.from the axel to front spring perch my truck measure 24inchs.to theback it measures 28 inchs.my wheels are b\about centered.works for me.
johnhull #812964 01/04/2012 12:50 AM
wdombrowicki, that is definitely not a stock rear location. Probably a swap. Another solution that I have seen was moving the rear fenders on the box a couple of inches. Don't recall if or how they modified the running boards.......it was a Ford. Let us know what you end up doing.
40casey #812998 01/04/2012 2:23 AM
what are the chances someone turned the springs around.i would think it would be worth measureing the springs before making any big dicision.one way or the other you need a new driveline
johnhull #813010 01/04/2012 2:55 AM
The measurements are correct I have a 115" wheel base I was wondering if they made a longer running board for a 3/4 ton truck because the 3/4 ton truck is listed as being 8" longer. But I didn't think that the 3/4 ton truck came with a box.
wdombrowicki #813083 01/04/2012 5:58 AM
Looks to me that you have the wrong running boards. If the rear end is in stock location it align with the curve in your frame. Plus looking at your pictures the fender mounting holes are way off. My boards measure 83" on the outside tip to tip.
Gmans 46 #813085 01/04/2012 6:05 AM
It looks to me that the rear of that fender needs to be propped up by about 3 more buckets. I can see the bed holes above the fender. Perhaps try placing a bolt in the upper hole and it won't looks so far off.
He posted under paint and body also. His boards measure 79" they're not going to work unless they're lengthen or replaced. A full picture of the truck and running boards or even a shot of the undercarriage would help but I believe his boards are the culprit.
Gmans 46 #813103 01/04/2012 7:19 AM
The running boards on my 1/2 ton measure 83" as well. If you add 4" to your 79", plus lift the rear of the fender into the right position, you are getting a lot closer ?
wdombrowicki #813135 01/04/2012 2:37 PM
My boards are 79" so someone must have cut them off. All though they look unmolested. Can anyone tell me how far the fender sits off the ground the bucket is the same height as the running board so I assumed that would be where the bottom of the rear fender would also sit . Also would it be ok to slide the rear end 2" foward without hurting the driving capabilities of the truck. I really don't want to try and find another pair of boards for the ones I have are excellant other than being to short. Thanks Wayne
wdombrowicki #813170 01/04/2012 4:32 PM
1 Offline
My 3/4 ton 1946 came with a box. And yes the running boards are longer also.
Trombones Totem Poles And Old Trucks!
wdombrowicki #813308 01/04/2012 11:16 PM
IMO I would fit the fenders in the correct mounting holes and adjust as needed. What are your plans for the truck? Stock, modified etc. If you are staying stock how do you move the diff forward with an enclosed drive shaft? I know how hard a primo set of boards are to come by but I wouldn't base my build on them. I would rather spring for a correct fit. JMO. I guess it depends on what you want to accomplish with your truck. Good luck with your build. I'll bet those boards came off an earlier model though.
Gmans 46 #813312 01/04/2012 11:44 PM
the truck had 47-54 rear fenders on it when I got it so the holes in the box aren't correct unless the box came off a 47-54. I going to try to make it as stock as possible. Gmans looked at your pics and it looks like your rear fenders angle up I've seen trucks with the fenders up higher but I would think that the bottom of the fenders should line up with the bottom of the running boards and front fenders. The drive shaft was converted to an open shaft before I bought it so shorting up a little would be easy. But I worry about the the functionality of the truck if I do that.thanks wayne
wdombrowicki #813411 01/05/2012 4:27 AM
How wide is your bed?
1939= 46.5 inches wide
1940-1947.1= 48.5 inches
1947.2-1987= 50 inches
There is something about the radius of that running board that doesn't look right either. More pics might clear things up. It's really hard to tell from the 1 pic provided.
There are fiberglass fenders and running boards available. Steel boards and fenders are a bit harder to find.
bigbadswingdaddy #813640 01/05/2012 10:14 PM
I deffinitly learning more than I think I wanted you guys are a load of information. Measured the box it is from a 47-54 did a little checking an found that the 37-40 has a 2" shorter wheelbase I'm guessing that is where the running boards come from. Now I have to figure out what the heck to do????????????
wdombrowicki #813788 01/06/2012 5:22 AM
Search and destroy! LOL. Don't feel bad, When I brought my basket case home it was sitting on a AD frame with a Pacer front end and a Dana 30/35 3:55 spool under it. Nothing would mock up right so I started over and sold what I couldn't use. Buy, sell and trade to get what you need to make her right for you. There's a wealth of knowledge here as I found out when I started my project. Have fun with it after all it's just nuts and bolts.
wdombrowicki #813789 01/06/2012 5:24 AM
The radius is wrong on the running boards. 40 uses the same rear fenders as 46. 39 rear fenders are 1 inch wider than 40-46 fenders. The running boards are likely from a 47-54.
wdombrowicki #814010 01/06/2012 11:46 PM
You have been alot of help I guess what I'll do is get the engine back in and running then get the cab and front done tnen decide what to do with the box and running boards my best guess would be to replace both. I'm sure I am going to need alot of help with this 46 before I'm finished and do appreciate all the information at least most of the mystery is solved. Thanks Wayne
wdombrowicki #814901 01/09/2012 9:29 PM
my 46 1/2ton rear fenders are centered, they are all original, untouched
