3 members (JW51, tesa, Ponchogl),
49
0
Mod | | | Forums66 Topics128,076 Posts1,055,925 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2009 Posts: 152 'Bolter | | 'Bolter Joined: Aug 2009 Posts: 152 | I got tired of the hood banging on my head so I installed a new pair of hood hinge springs from LMC. The hood still won't stay up without the trusty wood prop. What gives? Any suggestions?
Oldbolter 1959 Apache 3800 dually flat bed/dump with 261 1956 3800 dually flat bed/dump with 235 1957 3600 flat bed, 350 engine, 700R4, PS, disc brakes, 14 bolt rear with 4.11 gears
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Thats strange. Is the hood exrta heavy with undercoat? They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Aug 2009 Posts: 152 'Bolter | | 'Bolter Joined: Aug 2009 Posts: 152 | No undercoating. Nothing on or under the hood that shouldn't be there.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | your hinges have worn pins, a common problem with hood fitting and opening problems, the springs rarely are "bad"
Bill | | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | EDIT: I just noticed that your truck is a '59. I believe that it has different hood springs that AD trucks. If so, disregard my answer below ...
The hood of my buddy's '53 F-100 panel requires a "wood prop", too. He believes that the hood spring were installed a half-turn too loose after the restoration. Don't know if that is right, or if it is applicable to your Chevy. The F-100 spring and the AD spring are similar. I think that his hood springs are new reproductions. He hasn't attemped a repair yet.
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Aug 2009 Posts: 152 'Bolter | | 'Bolter Joined: Aug 2009 Posts: 152 | Thanks Bill, I hadn't considered the pins. You saved me from trying yet another set of springs. One more reason why the members of this forum are the best.
| | | | | Joined: Sep 2010 Posts: 166 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 166 | Oldbolter, I had the same problem with my hood on my '59. Sent my hinges to Willie Wilson, does great work, cleans, blasts, repairs, will even powdercoat if you wish. http://hoodhingerepair.com/Darren | | | | | Joined: Aug 2009 Posts: 152 'Bolter | | 'Bolter Joined: Aug 2009 Posts: 152 | Darren,
Thanks for the link. I checked the web site and this looks like what I need.
| | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Are the springs for the 55 2nd to 57 different from the 58-59? If so, are the ones you have the wrong springs?
Just a thought
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Aug 2009 Posts: 152 'Bolter | | 'Bolter Joined: Aug 2009 Posts: 152 | Dennis,
Your post really got me to thinking - maybe I did put the wrong springs on it. So, I found the packaging material and checked: they are marked '58-'59. It looks like I'm back to rebulding or replacing the hinges.
| | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Sorry. I wished I could have helped
