1 members (homer52),
66
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2009 Posts: 44 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 44 | Just got my 37 jalf ton pickup back from the paint shop. I had removed the data plate (with serial number) from the right side cowl underhood before taking it too be painted. Unfortunately my friend did such a good job, that he filled all the holes for the plate. I also don't have the "second plate" as seen next to the data plate. Does anybody have a good photo that shows the exact location of either plate. Any help/ measurements are appreciated. Jeff | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Pre restoration pic of my '38, they should be the same. You should be able to pull the kick panel inside to get the exact location of the holes.
| | | | | Joined: Feb 2009 Posts: 44 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 44 | Thanks to both of you. I'm out of town, but will pull the kick panel this weekend. Interesting thing is your two trucks have them in two different orientations. | | | | | Joined: Feb 2009 Posts: 44 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 44 | I like the town and country horn photo also. I've been looking for a set as I finish up the truck. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Interesting thing is your two trucks have them in two different orientations.  I forgot to mention that my '38 is a coupe, that most likely explains the difference. Geeze, you'd think one of these days I'd get old enough that the gray matter works ALL of the time.
| | | | | Joined: Feb 2008 Posts: 1,122 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,122 | 1937 Data Plate Location on my half ton. It is the upper plate showing the production location and number, the lower plate is missing. Note that the long axis is verticle and the alpha-numeric characters side is on the right. It is mounted with clutch head screws. I have wondered what the lower plate info is supposed to look like. Can you show the lower data plate info for your truck? Hope this helps. By the way I am fairly certain the orientation is correct. The truck came from the factory Commercial Red. A later owner painted the truck "Mariner Blue". I discovered the Red color under the plate. | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | My 37 pickup plate locations match Tiny's and 37Blue's. It would be nice to see an "newer" set of plates to know exactly what they look like. Thanks!
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Sep 2010 Posts: 1,705 back yard wrench turner | | back yard wrench turner Joined: Sep 2010 Posts: 1,705 | 37Blue, it looks like your photo should rotate 1/4 turn clockwise. It then would match my '38. Of course I may be looking at it wrong.
Wayne1938 1-Ton Farm TruckStovebolt Gallery Forums1989 Silverado 1996 Mustang GT convertible When I die, I hope she doesn't sell everything for what I told her I paid for it! | | | | | Joined: Feb 2008 Posts: 1,122 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,122 | Wayne: My '37 truck matches the photo in your first reply showing a truck cab; long axis verticle. The mounting holes only allow that orientation. What kind of info is shown the lower plate showing in your photo? My second plate was missing and I've wondered if it had info similar to that given for cars. Thanks, 37Blue. | | | | | Joined: Sep 2010 Posts: 1,705 back yard wrench turner | | back yard wrench turner Joined: Sep 2010 Posts: 1,705 | 37Blue, my lower plate is blank. There is no info stamped into the metal. I assume it had some painted info on it at one time, or maybe a decal.
You can enlarge my photo by holding down the control button and rolling the wheel on your mouse. Then click on my photo to enlarge it more.
Wayne1938 1-Ton Farm TruckStovebolt Gallery Forums1989 Silverado 1996 Mustang GT convertible When I die, I hope she doesn't sell everything for what I told her I paid for it! | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Check from inside the cab and you may be able to find remnants of those original filled holes. Good luck | | |
