1 members (Peggy M),
121
Mod | | | Forums66 Topics128,072 Posts1,055,904 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2011 Posts: 196 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 196 | OK- so after all the recent posts I thought I'd better take a look at what my numbers say.
So here is what I have found thus far:
DBA339360 (next to dsitributor) + down to the right of the distributor it looks like just two digits: 20
839401 (on top by valves) + CONY12
Little confused here. Thanks! | | | | | Joined: Jul 2005 Posts: 581 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 581 | Engine Serial# : . D=1946 . B=Reg. Prod. 1/2 ton . A=Flint MI . #'s=Sequence Head # was used thru the 40's. Standard 216. Between the exhaust valve of 4 & 5 there is another number like "L26 6". The L is the month, 26 the day, and 6 the year; so Nov. 26th, 1946.
| | | | | Joined: Nov 2011 Posts: 196 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 196 | Great. Thank you. I will look for the other numbers. What does the "conv12" or "cony12" stand for? I saw it noted in one of the previous posts, but no explanation. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | It supposedly refers to the assembly line CONVeyer number.
| | | | | Joined: Nov 2011 Posts: 196 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 196 | Bingo : J56 October, 5th 1946! Thanks again, now I just have to get it to turn over!  Andy | | | | | Joined: Apr 2005 Posts: 507 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 507 | Remember the letter I and O are not used to indicate the month of the casting.
"If it ain't Steel it ain't Real" "Earth the insane aslyum for the rest of the Universe" 41 1/2-ton, a work in progress 68 Shortbed stepside 327/325hp/700R4
| | | | | Joined: Nov 2011 Posts: 196 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 196 | Ohh.... Didn't know that!!! So J = September!!
Thank you! | | | | | Joined: Nov 2011 Posts: 196 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 196 | On second thought the skipping of the "I" and the "O" certainly contradicts the link Tim psoted about the head and date casting codes earlier in this thread!!?! | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Andy,
I do not know about the I/1 and O/0 being skipped on USA Chevrolet trucks. But, it is possible.
I do not have GM documentation on date casting codes. I'd be interested in learning that my interpretation is wrong.
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I do not think Tim is wrong in this case.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Apr 2005 Posts: 507 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 507 | only the letters I and O are not used to prevent confusion with the numbers 1 and 0.
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I have several problems with that statement. First there is no need to use "O" as "L" is the 12th letter, M if L is not used. Second I am pretty sure I have seen an "I" used. This would also mean that M was used and I do not remembering ever seeing that.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Dave, Thank you for your post. It confirms what I had thought was the case on blocks/heads but I have no supporting documentation. 41Chevy's comment about Os and Is tweaked my unreliable memory regarding that practice - I think I now remember where I read that Is were not used in AC Delco Remy (Division of GM) date codes: example 1 (for Is); example 2 (for Is); and, example 3. | | | | | Joined: Apr 2006 Posts: 506 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 506 | Good point Dave for month "O" Ditto, A thru L.
The letter "I" was not used in the vehicle serial number, year.
Example, 1950 = "H" 1951 = "J"
-Tom
1950 Chevy 3100 w/ 1956 235
