Again, I don't want to bad mouth any of my 'bolts PO's, they have to do what gets them on the road! Here's the
rear motor mount ! New rubber is on it's way, just not sure about the bolt, can't locate any specs on what size it
should be, or whether a flat and/or lock washer should be on it. Once I get the rubber in hand I'll go shopping.
Just pulled the Left side bolt, see now that it is just a big ol' bolt, no nut. Screws into the block. Any suggestions on how to get the old top rubber off? Do you have to jack the engine up in back? Sorry, yes it's a 56 SB 235 3 on the tree.
Just to stay on subject, I'll edit this post to add another
PO Mystery . Any idea what this piece of leather wraped around the clutch fork might be? Looks like PO was concerned about dirt entering the tranny, but this thing is so "engineered" it might really belong there. Ever see one of these?
