1 members (Hotrod Lincoln), 41 guests, and 0 robots.
Topics128,035
Posts1,055,560
#813038 01/04/2012 3:47 AM
Hi everyone I recently just purchased a 1947 2nd series Chevy half ton pickup. It has the 3 speed floor shift transmission. I was wondering if this 3 speed is the same transmission as the column shift 3 speed or if it is a different beast. If anyone has a link to any information about this transmission that would be great too. Thanks!
47bolter #813045 01/04/2012 4:00 AM
If it is a floor shift, it is probably a sliding gear transmission with no synchronizers. A later model has a different bolt pattern. Are you sure its a 3 speed and not a 4 speed?
crenwelge #813049 01/04/2012 4:08 AM
I'm pretty sure. The 47 2nd series were using the SM420 right? It doesn't have the drivers side PTO side cover a SM420 would have. I haven't driven it yet to find out where reverse is because the gas tank is out for some TLC. I was feeling around with the shifts today and to my knowledge reverse in the SM420 is towards you and back and there is no gear there. It also has the original torque tube so I'm sure its a factory transmission.
47bolter #813082 01/04/2012 5:55 AM
From what I have found out on line and from my shop manual (1947 AD (Thriftmaster) or 1947 second series) is that the '47 came with a three speed on the floor with synchros or a four speed without synchros. The SM 420 wasn't used until 1948.My transmission is a four speed with no synchros. There is a reverse lockout lever rod that runs along the side of the shifter which is activated by lifting up on a 'tab' to the right and just below the knob. On the SM 420 you push down on the shifter and put into reverse position. My transmission has a PTO plate.
It's a small world, but I wouldn't want to paint it.
Thats interesting. I did not know that the 47 second series had different transmissions than the later AD pickups. My shifter does not have the reverse lockout. A week before I got this truck I looked at another 47 and it had a shifter I hadn't seen before. From the description of your 4 speed I think thats what it might have been. Here is a picture
https://picasaweb.google.com/lh/photo/UQjrPE2C2ncs4fQviRzr7NMTjNZETYmyPJy0liipFm0?feat=directlink
ps Since it sounds like you also have a 47 AD, what shop manual did you go with? The 47 only or the 48-53 one?
47bolter #813247 01/04/2012 8:01 PM
My manual is for the '47. (It came with the truck when I bought it.)Part suppliers will state '47 - '53 but in regards to transmissions it's actually '48 - 53. I purchased a rebuild kit form Novak's thinking I had an SM 420 but had to return it. I supposed because '47 was a 'crossover' year there was some carry over of parts from the pre-'47's.
If it is indeed a 3 speed, this is probably the transmission.
https://picasaweb.google.com/crenwe...Gv1sRgCI6NzZa90ImDBg#5693930561278736146
The Chev parts book list it as 1937 through 1947. And it actually is a synchronized transmission because sit has a synchro clutch.
47bolter #1025940 05/03/2014 4:54 PM
BFT Offline
I need one of these transmissions if anyone has one for sale
Please call me!! 3O3.8I5.5435 - Mike, Colorado
1941-47 3 Speed Top Shift
Photo Here
BFT #1025961 05/03/2014 7:13 PM
Originally Posted by BFT
I need one of these transmissions if anyone has one for salePlease call me!! 3O3.8I5.5435 - Mike,Colorado 1941-47 3 Speed Top Shift Photo Here
Maybe this is what your looking for.
1937 Transmission Chevy Truck FLR,3SPD,GEARS LOOK GOOD,NEED REBUILD L04397 $300 All American Classics USA-WA(Vancouver) 1-800-955-4999
Source
