6 members (32Fordpuchoptop, Youngin' Tut 59, treegrower, Gray_Ghost, Wickedbass, WICruiser), 66 guests, and 3 robots.
Topics128,076
Posts1,055,922
Members48,430
#812787 01/03/2012 2:13 PM
V
V Offline
Hi all Bolters. Hope you all had a nice Christmas and that the New Year will see more Bolts back on the roads once again.
My truck is now converted to a 12 volt system. My question is? Can my 6 volt horn be used with a 12 volt system? Does it require a Resistor or some other device to step the 12 volts back?
Ex Hall Monitor
Ex Hall Monitor
You're fine as long as you don't lay on the horn and hold it there. For normal usage you'll just see (hear) a louder horn.
Does your 6v horns use a horn relay? If not, probably a good idea to install one. If it has a relay, I believe that the 6v relay will work with 12v. (?)
I installed a pair of 6v Chrysler Corp trumpet horns on a friend's 12v Triumph Spitfire in the 70's. His wife had complained that drivers could not hear the Triumph's anemic little horn. The blast from those 6v horns would almost push the lil' Spitfire backswards when she tooted them. Anemic horn problem solved!
- Lonnie
My '54 3104
I'm running the stock 6V dual horn set up on my 51 panel and they
are connected to a brand new Painless 12V wiring harness.
The first time I hit the button, LOTS of old stuff blew out and then they
sounded like a semi on the freeway! Love the sound
squire
Ex Hall Monitor
Ex Hall Monitor
As a kid I remember that every time Dad would buy a "new" car he'd go to the salvage yard and bring home a set of 6v horns. The 12v just weren't loud enough for him.
I'm running dual 6V horns through a 12 volt relay and they do get your attention.
I'm running a set of 6V Oldsmobile horns on 12 in my Suburban. They also get attention.
V
V Offline
Thanks again to everyone! I hooked up a new 12volt relay and they work real good. Its great to have info like this. Sure takes the guess work out.
