2 members (sron48, Gray_Ghost), 105 guests, and 4 robots.
Topics128,078
Posts1,056,052
Members48,433
#812789 01/03/2012 2:25 PM
I have installed a rebuild kit but still get hesitation on accerlation, any help?
Ridge dweller
ridgeview #812793 01/03/2012 3:05 PM
Had the same issue running a pair of them on a 55 pickup several years ago. Never could figure it out.
1955 Chevy 3100
hb32 #812797 01/03/2012 3:17 PM
have you checked your timing?
With the engine off and air cleaner removed, look down the throat and pump the accelerator to make sure the diaphram is pumping a good stream of gas.
Also, check to see if the throttle shaft is worn and has any play in it which could be a source for an air leak.
Allan
1951 GMC 1/2-ton
Two 1953 Chevy 3100 5-window
magfarm51 #812886 01/03/2012 8:59 PM
Carburetion specialist
The accelerator pump circuit for the W-1 has:
(A) bracket bolting to throttle shaft with a round hole that becomes elongated
(B) Rod from bracket (A) to cross arm which wears a groove
If either the bracket or the rod wear as above, a hesitation can certainly occur. Replacing these parts often will eliminate a hesitation if the carb is the culprit.
A misfunctioning distributor will also cause a hesitation.
Jon.
The Carburetor Shop
