0 members (),
93
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2001 Posts: 81 Shop Shark | | Shop Shark Joined: Feb 2001 Posts: 81 | I have a 62 1/2 ton Chevy pickup with a 235 c.i. six engine. I have points and am thinking of converting to an electronic system while using my original distributor. What would be the best brand to convert to and what benefits could I expect?I have used points and install them myself since 1978 but am having difficulty purchasing American parts-the Chinese parts just don't last!!! Thanks for any ideas.. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | If you want to use your original distributor, The Pertronix electronic unit may be your only choice. If your wiring is good and your grounds are good/clean, you should have no problems.
| | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | Check out the tech tips, you can take a HEI out of a newer 6 cylinder and make it fit a 235. It's fairly simple and easy to do. I don't know what the new ones cost, but finding a used one at a salvage yard should be cheap? | | |
