2 members (78buckshot, IHPWR), 88 guests, and 1 robot.
Topics128,024
Posts1,055,395
Members48,422
#812593 01/02/2012 11:22 PM
1 Offline
Im going to trade my 1/2ton beds tomorrow for a 3/4ton bed. the bed im trading for is still bolted to the frame and i was wondering how to remove it any tips? Both beds i have where already separated so i didnt have to take mine off.Its two hours away so i wanna make sure im prepared before i go out there.
mostly you just need to remove the main bed-to-frame bolts if you're taking the works, need a good socket set as well as a hammer and chisel to snap off bolts that protest .... and something comfortable to lay on the cold wet ground grin
Flxible #813042 01/04/2012 3:55 AM
1 Offline
are all of the cross braces bolted to the frame as well as the four corners?
3/4 tons have 8-bolts/ 6 bed blocks (the rear sill has the two metal brackets) and they have one floating cross brace over the frame hump that bolts only to the bed not the frame.
