| | | Forums66 Topics128,109 Posts1,056,253 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2007 Posts: 231 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 231 | Im going to trade my 1/2ton beds tomorrow for a 3/4ton bed. the bed im trading for is still bolted to the frame and i was wondering how to remove it any tips? Both beds i have where already separated so i didnt have to take mine off.Its two hours away so i wanna make sure im prepared before i go out there. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | mostly you just need to remove the main bed-to-frame bolts if you're taking the works, need a good socket set as well as a hammer and chisel to snap off bolts that protest .... and something comfortable to lay on the cold wet ground Bill | | | | | Joined: Oct 2007 Posts: 231 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 231 | are all of the cross braces bolted to the frame as well as the four corners? | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | 3/4 tons have 8-bolts/ 6 bed blocks (the rear sill has the two metal brackets) and they have one floating cross brace over the frame hump that bolts only to the bed not the frame. | | |
