4 members (Wally / Montana, Otto Skorzeny, baldeagle, joe apple), 72 guests, and 0 robots.
Topics128,078
Posts1,055,940
Members48,430
#812512 01/02/2012 5:14 PM
SPL
Offline
I put a new harness in my '49 and now want install my heater switch and wire it to the heater motor (6V). I need to know wire guage to use and the correct terminal from which to get the power for the heater. The switch terminals are marked B and M. I assume M means it's the motor terminal.
SPL #812521 01/02/2012 5:40 PM
The installation manual says to get power from the dead terminal on the ignition switch (dead when the ignition key/switch is in the Off position).
If you have the original heater-motor switch. Facing the front of the switch, the power-in goes on the left terminal and the power-to-motor goes on the right terminal (the terminal closer to the heater when the switch is mounted under the dash).
SPL
Offline
Thanks. What about wire guage and fuse size?
SPL #812569 01/02/2012 9:33 PM
SPL this Link should help ...
1954 Chevy 3104 3 Window Hydra-Matic in my family for over 60 Years
Once in a while you get shown the light in the strangest of places if you look at it right... "Scarlet Begonias" Grateful Dead 1974
