11 members (Jay R, wilbur53, Gdads51, TUTS 59, DaveV, RLB, WICruiser, Phak1, Otto Skorzeny, 55shaker, 1 invisible),
109
Mod | | | Forums66 Topics128,056 Posts1,055,789 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2010 Posts: 27 New Guy | | New Guy Joined: Apr 2010 Posts: 27 | I put a new harness in my '49 and now want install my heater switch and wire it to the heater motor (6V). I need to know wire guage to use and the correct terminal from which to get the power for the heater. The switch terminals are marked B and M. I assume M means it's the motor terminal. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The installation manual says to get power from the dead terminal on the ignition switch (dead when the ignition key/switch is in the Off position).
If you have the original heater-motor switch. Facing the front of the switch, the power-in goes on the left terminal and the power-to-motor goes on the right terminal (the terminal closer to the heater when the switch is mounted under the dash).
| | | | | Joined: Apr 2010 Posts: 27 New Guy | | New Guy Joined: Apr 2010 Posts: 27 | Thanks. What about wire guage and fuse size? | | | | | Joined: Sep 2009 Posts: 433 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 433 | SPL this Link should help ...
1954 Chevy 3104 3 Window Hydra-Matic in my family for over 60 Years
Once in a while you get shown the light in the strangest of places if you look at it right... "Scarlet Begonias" Grateful Dead 1974
