| | | Forums66 Topics128,152 Posts1,057,011 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2000 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2000 Posts: 60 | HEY ALL, NEED IDEAS FOR POWER STEERING FOR A1949 CHEVY 1/2 TON THATS ALL STOCK  AND WANT TO KEEP IT THAT WAY... THANKS TRUCKMAN
FRAMEUP TRUCKS - 47/55.1ST STILL PLAYING WITH TRUCKS | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Sounds like a conflict of interests?
You want power steering and you want to keep the truck all stock?
| | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | We used to call it Armstrong power steering. Strong arms and learning to drive without P/S. | | | | | Joined: Sep 2000 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2000 Posts: 60 | WELL GUYS THE MAN IS IN LATE 60'S HE JUST NEED'S A LITTLE HELP TURNING THE CORNER.
TRUCKMAN
FRAMEUP TRUCKS - 47/55.1ST STILL PLAYING WITH TRUCKS | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | I'm in my "very" late 60's, a few months away from my 70's and just a scrawny little fella. With a good set of tires and the correct front end geometry I can turn corners quite easily in my “completely stock” 1950, ¾ ton with one hand on the wheel and the other out the window signaling that turn.
Where I could use a third hand is shifting into my second gear choice in the middle of those turns.
If these trucks are “restored” correctly a child could steer them with the wheels rolling. Now parallel parking in town with a line of cars waiting to pass presents a whole new set of problems.
I do have a good friend with advanced COPD who could really use PS on his 1950, 3104. I’ve been looking for years for some simple way to get PS on his truck with out changing the steering gear and I haven’t found anything yet. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | There are kits out there for this. I think the popular mod involves replacing the steering box with one from a power steering setup. Some use a box from a Toyota truck. They cut the steering column just above the box and put a secure union on to join it to the new box. All the truck suppkiers carry a new Pitman arm for this application.
I agree with the above comments in that having tires with good tread makes steering quite easy. When the truck is stopped, it takes a little more work. The steering in my 1 Ton is very light when driving down the road.
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Yes there are mods that require changing the steering box, steering column and other steering components. All of them are quite involved and they are not just a simple bolt on addition to the stock steering, which I think is what the poster had in mind.
DG
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Yes, it would be quite involved. I mentioned it because it seems to be the most popular way of adding power steering. In addition, one would have to add the pump and brackets and then get into the problem with pulleys. | | | | | Joined: Jul 2008 Posts: 326 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 326 | Truckman; There were "ram" power steering setups on early Chevies. I had one on a 55 sedan and a 66 Chevy II. They use the standard manual box and a hydraulic valve on the tie rod. I think they were used up until the mid 60's. You can still get rebuild kits, etc. See this post for some photos. Ram power steering SimS | | | | | Joined: Sep 2000 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2000 Posts: 60 | SimS
THAT'S WHAT I WAS TRYING TO REMEMBER... THE POWER RAM OR A OTHER NAME FOR IT.. THANKS
SO GUYS DOES ANYONE HAVE ANY IDEA'S WHERE TO GET ANYTHING LIKE THIS.....
THANKS TRUCKMAN
FRAMEUP TRUCKS - 47/55.1ST STILL PLAYING WITH TRUCKS | | | | | Joined: Jul 2008 Posts: 326 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 326 | Classic Performance Products has kits for 47-52, 53-54 & 55-59 trucks. There are probably other vendors too. You could also assemble your own from individual parts.
SimS | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | As we've been saying, it's not a simple modification, it's quite involved, ya need to read the procedure not just the heading: http://www.classicperform.com/power2.htm Denny Graham Sandwich, IL
| | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | I'm only a year behind Denny and I have no desire for power steering on my old jalopies. I think that is part of the nostalgic experience of driving them. And its not going to look stock by any means. | | | | | Joined: Jul 2008 Posts: 326 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 326 | Denny;
Your link references changing out the entire steering gear with modern parts. I agree that is a bigger deal. The "power ram" steering just replaces the existing tie rod and bolts on a hydraulic cylinder. Still it involves some labor but it is much less intense than the whole steering column, steering gear route. I'm with you, a well maintained manual system on these trucks is good enough even for this scrawny old guy.
SimS | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | I'm doing a CPP power steering installation like Denny links using a 71-87 C10 box on a buddy's '55.2 right now-the kit is for '47-59. It's pretty involved, truck is on a lift & I got about 4-5 hours in it at least, still haven't got the column back in. Shocks must be relocated to the rear of axle, fenderwell trimmed, etc etc. Great setup though, fits like a glove, and should work great. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | and with that CPP kit, note well the detail at the very bottom, an incorrect pitman will cause grief, a buddy here had it done to his 56 panel and it took much head scratching to figure out why it handled terribly, even after modifying the original job it's still poor .... and per the original post here, it sure doesn't look stock  I'm with the other oldsters above, if you can't stand "armstrong steering" buy a newer vehicle, one finger steering is only needed by those that use the other fingers for texting  Bill | | | | | Joined: Mar 2010 Posts: 1,660 Curmudgeon | | Curmudgeon Joined: Mar 2010 Posts: 1,660 | If I get to the point where I can't "armstrong" my truck, I'm not going to sell it. I like the rattles, noise and shifting gears. I don't need a step ladder to put something in the bed like new trucks. I'll modify my truck before I let it go. From what I've read, the technology is coming that puts power steering units under the dash as a retro fit. Unfortunately the cost is terrible and it would require conversion to 12V alternator for the current requirement. Here is one company: www.ateliersemva.com click on English
"Adding CFM to a truck will only help at engine speeds you don't want to use." "I found there was nothing to gain beyond 400 CFM." | | | | | Joined: Sep 2000 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2000 Posts: 60 | THANKS FOR THE IDEAS GUYS...WE ARE GOING AFTER THE " POWER RAM " AS FOR ARMSTRONG IT, I CAN DO IN HIS TRUCK, THE TRUCK IS VERY WELL MAINTAINED. HE WAS IN A WRECK A FEW YEARS BACK, DOES GOOD TO LIFT 20 POUNDS AND IS GETTING BACK ON HIS FEET.... ONE THING HE SAYS IS I'M NOT SELL MY TRUCK..
FRAMEUP TRUCKS - 47/55.1ST STILL PLAYING WITH TRUCKS | | | | | Joined: Feb 2003 Posts: 452 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 452 | So, I'm looking at the parts available from Ecklers ( www.ecklers.com). The ram and the control valve are available for Corvettes. The control valve fits between the Pitman arm and the middle tie rod. The ram fits between the frame and the idler arm at the other end of the middle tie rod. My question is, how hard would it be to install this system in an AD truck with original steering? I can see the drag link would have to be modified to fit the control valve, and some method would have to be found to couple the ram to the tie rod... Given the price of the parts, it seems a reasonable solution.
Current fleet (subject to change w/o notice) \'49 GMC 3/4-Ton , 60 Austin Healey Frog-eye Sprite (some assembly required), 2011 Dodge Avenger, 2015 Jeep Cherokee. No, they don't all run. My other ride is a (B737)no, (B767)no, A320.... Update... was Embraer E190, now Boeing B787. Knowledge is a wonderful thing, but ignorance means you don't know you can't do something.
| | | | | Joined: May 2005 Posts: 487 'Bolter | | 'Bolter Joined: May 2005 Posts: 487 | Truckman,
What's your plan for attaching a power steering pump to the 216?
regards, Leon | | |
