1 members (Rusty Heaps),
84
Mod | | | Forums66 Topics128,143 Posts1,056,494 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 581 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 581 | From all outward appearances and the engine serial number(ADCA), my engine is a 1946 216. But when I went to change the plugs they were not the 10mm but 14mm plugs. The spec. book doesn't show 1-tons as having the 235 as a factory option. The casting # is 839770.
So did some PO machine for different plugs? Otherwise what plug should I now use for the "216"?
| | | | | Joined: Nov 2004 Posts: 266 Custom Title | | Custom Title Joined: Nov 2004 Posts: 266 |
49 Chevy 3600 65 Chevy K10 48 International KB-1 Service Truck 55 Willys CJ5 - Chevy 331 powered 26 Model T Roadster Rat Rod 70 Tucker Sno-Cat 442-A 96 Dodge 3500 Cummins dually flatbed x-cab 4x4 06 Jeep Wrangler LJ rock crawler If you can't fix it with a hammer, it's an electrical problem | | | | | Joined: Jul 2005 Posts: 581 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 581 | Yep, everything checks as a 216, which I thought it was. The spark plug size threw me. Someone must have enlarged it or a later head? I'll check that out too.
The plugs in it are old AC 46 which don't appear to have been made for some time. I've read that AC Delco R45 and R45s are what some are using now. Any other sizes/types?
| | | | | Joined: Jan 2007 Posts: 117 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 117 | same here i had some work done on my truck and the older guy says you have a 235 not a 216 which i thought i had ??in my 47 3/4 ton, 1947
care to chat write back
| | | | | Joined: Jul 2005 Posts: 581 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 581 | mickster, I checked all the numbers out on the block and the head with parts books and online sites. After all that everything checked out as being original except it was supposed to have 10mm plugs, which it din't. I have to believe somebody tapped them for 14mm. Not sure why they would do that, perhaps they stripped out the originals. | | |
