| | | Forums66 Topics128,051 Posts1,055,767 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 149 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 149 | i tried search,nogo.could someone point me the direction,install&the source of.yes i looked at mr.SWEETS pics.just enough get me to thinking.thanks | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | What year? Are you putting on a new kit or used parts? They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Aug 2011 Posts: 149 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 149 | my truck is a1954.i plan doing a junk yard serch. thanks | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | It looks like you are looking for the sway bar for your truck. An original sway bar on a 1952-1955 1/2 ton panel body truck should work fine on your 1954 1/2 ton truck.
Jim Carter sells the bushings set (and, he sometimes has a used sway bar set).
| | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | I found my sway bar on eBay then got the bushing kit as Tim mentions above. Its a fun easy project!!!
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Aug 2011 Posts: 149 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 149 | well i think ihave taking care of my heating problem,so i,m back reserching front sway bars.while at p/p notice there is an abundance of s10s.has anyone tried useing a swaybar off an s10? thanks again...front swaybar | | | | | Joined: Jul 2007 Posts: 328 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 328 | CPP sells a sway bar kit that bolts in. It is VERY heavy duty (1 1/8 inch bar) and uses same frame and chassis mounting points as a stock one. Comes with all Teflon bushings, hardware, U=bolts, and mounting brackets. I think it's about 169 bucks.
squire
| | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Most likely better than the stock one too. | | |
