2 members (Ponchogl, Hush),
67
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#81190 08/07/2007 4:00 AM | Joined: Jul 2007 Posts: 6 New Guy | | New Guy Joined: Jul 2007 Posts: 6 | I need to know what the correct track width is on a 1964 C10. I need the front and rear measurements. I am looking at purchasing another truck and the front tires seem to be further apart than the rear tires. Any help would be great! | | |
#81191 08/07/2007 9:02 PM | Joined: Apr 2003 Posts: 942 'Bolter | | 'Bolter Joined: Apr 2003 Posts: 942 | I don't have a track width available right now, but if the truck looks original, I would say that there are probably different wheels on there, that have different "offsets".
'60-'72 Chev/GMC Fan GMC 9500 Fan Detroit Diesel Fan
#81192 08/08/2007 4:16 AM | Joined: May 2006 Posts: 29 New Guy | | New Guy Joined: May 2006 Posts: 29 | I lowered my 64 21/2in. and went over to discs and it seems to have widened the front track approx an inch, wider that the rear. I didn't mesure it beforehand but noticed the the fender clearance was less. Just thought I'd throw my 2 cents in. | | |
#81193 08/10/2007 11:18 PM | Joined: Aug 2006 Posts: 29 New Guy | | New Guy Joined: Aug 2006 Posts: 29 | Vito, How did you lower your 64, springs or spindals? I would think springs would allow the increased width, but I would think lower spindals would not. I want to lower my 63 and am unsure which way I will go.
Rick | | |
#81194 08/11/2007 12:35 AM | Joined: Dec 2001 Posts: 141 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2001 Posts: 141 | Porter, the front end on my '66 is darn near 73" from outside of rim to outside of rim (standard rims, not sure of any offset). Hope that helps.
I know that using the lower control arm and spindle will increase the width about an inch, but doing this will require you to remove all the shims from the upper control arm, because the later model lower control arms are mounted closer together at the crossmember. Even if you did that, the width will increase about an inch (know someone that did it).
I changed the entire crossmember out (check out my progress on my website); haven't gotten any measurements as of yet, but I expect the width to increase some. If I make a junkyard run tomorrow, I'll see what the width of a '75 is. | | |
#81195 08/13/2007 4:09 PM | Joined: Jul 2007 Posts: 6 New Guy | | New Guy Joined: Jul 2007 Posts: 6 | Hey Guys,
Thanks for the help. Sorry it took so long to reply,life is busy. After I got the wheels off and measured it was only about an inch or so. The guy I got it from put a drop shop front end on it with 1972 chevy disk brakes. Thanks again! | | |
