3 members (jay d, 2 invisible),
54
Mod | | | Forums66 Topics128,009 Posts1,055,292 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 324 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 324 | just installed a tilt steering column from a 1993 Astro in my 49 Chevy pickup. It worked out very well. Also found a nice shift indicator & pointer for a 3 speed 700r4 from an old 80's van from a junkyard. The indicator mounts ok on the upper part of the column, under the steering wheel, which always remains stable. My problem is when the wheel is tilted up or down the pointer is moved away or closer from the indicator letters, depending on the tilt position its never in the right spot? Is there anybody that has solved this problem? Any advise on how to approach this?? Any of you guys have any suggestions?
