1 members (Otto Skorzeny), 54 guests, and 3 robots.
Topics128,054
Posts1,055,779
#811448 12/30/2011 2:20 AM
what can I replace my 1950 3/4 ton rear axle with? will S-10 axles fit? if so what years. I want to upgrade my bakes.
evac34 #811892 12/31/2011 4:06 PM
does anyone have any thoughts....I am not sure what to do. Any help would be appreciated
evac34 #811904 12/31/2011 4:58 PM
ODSS President
ODSS President
Start reading, that challenge has been posted a number of times, do a search, go to 'The Gallery' and look at vehicles in your vintage, some have posted links to what you would like to do.
~ Cosmo
1949 Chevy Half Ton
Cosmo #812397 01/02/2012 3:56 AM
Evac> Your best bet is to find a Ford or Dodge van rearend. I believe a 73 on up GM 14 bolt will work also. They'll be a little, wider but they should work. You'll have to do some fabricating by cutting off the old and welding on new spring and shock mounts. If you want to upgrade your brakes on all 4 corners, try finding a 1/2 ton front axle assembly and a later model 6 lug rearend.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
Whitedog #812405 01/02/2012 4:12 AM
I'm with Whitedog on this, having helped do a Dana 60 swap on a '49 3800. The Dodge version is a perfect fit. It would be much better that going to an S10 or passenger car rear with much smaller brakes.
Bill Burmeister
LONGBOX55 #812416 01/02/2012 5:08 AM
I used a rear end from a 78 Lincoln. It is a 9" ford and had disc brakes. It was almost the same width as the stock rear end.
Remember 9-11-01--God Bless the USA
JUSTICE, not REVENGE, will prevail
1951 Chevy 1/2-ton Pickup truck
evac34 #812518 01/02/2012 5:35 PM
thanks for the input...looking for a 1/2 ton front end now. got my fingers crossed I can find one
