4 members (klhansen, Uncles51, CharlieF, 1955 1 Series), 88 guests, and 2 robots.
Topics128,080
Posts1,056,294
Members48,441
From all outward appearances and the engine serial number(ADCA), my engine is a 1946 216. But when I went to change the plugs they were not the 10mm but 14mm plugs. The spec. book doesn't show 1-tons as having the 235 as a factory option. The casting # is 839770.
So did some PO machine for different plugs? Otherwise what plug should I now use for the "216"?
1941 G506
More
1946 3800
Pic
More
1946 3600
Pic
More
1924 Ford Model T Fordor
This will probably answer your question re. 216 or 235 engine.
http://www.stovebolt.com/techtips/engine_identification.htm
Harold
Harold
Custom Title
Custom Title
839770 = 42-53 216
49 Chevy 3600
65 Chevy K10
48 International KB-1 Service Truck
55 Willys CJ5 - Chevy 331 powered
26 Model T Roadster Rat Rod
70 Tucker Sno-Cat 442-A
96 Dodge 3500 Cummins dually flatbed x-cab 4x4
06 Jeep Wrangler LJ rock crawler
If you can't fix it with a hammer, it's an electrical problem
Yep, everything checks as a 216, which I thought it was. The spark plug size threw me. Someone must have enlarged it or a later head? I'll check that out too.
The plugs in it are old AC 46 which don't appear to have been made for some time. I've read that AC Delco R45 and R45s are what some are using now. Any other sizes/types?
1941 G506
More
1946 3800
Pic
More
1946 3600
Pic
More
same here i had some work done on my truck and the older guy says you have a 235 not a 216 which i thought i had ??in my 47 3/4 ton, 1947
care to chat write back
mickster, I checked all the numbers out on the block and the head with parts books and online sites. After all that everything checked out as being original except it was supposed to have 10mm plugs, which it din't. I have to believe somebody tapped them for 14mm. Not sure why they would do that, perhaps they stripped out the originals.
1941 G506
More
1946 3800
Pic
More
1946 3600
Pic
More
