4 members (KEVINSKI, jay d, Otto Skorzeny, k2handyman), 152 guests, and 2 robots.
Topics128,034
Posts1,055,552
#810311 12/25/2011 10:02 PM
Hi all...Merry Christmas to all...my question concerns the pre-fix to the casting number on my 1946 Chevy ¾ ton pickup (GM 839770). I can't find out what the GM is for...I though the correct pre-fix was DA??? Not sure if this was a GM Truck motor that was used for a re-furb job? Any help would be appreciated.
389770 is a 216 casting number, GM General Motors.
The numbers you should be looking for to find the "DA" will be stamped next to the distributor.
My Blog
Thanks Dave...I check their tonight after Turkey...
Merry Christmas and a Happy New Year. John
For a stock 1946 engine I believe your prefixes will be: BG or BL for a first series, DAA, DDA, DDM, DEA, or DEM for a 2nd series.
So if my prefix is DDA on a 1946 Chevy 1/2 ton, is the block a 216 or a 235? I've looked at different casting number sites (such as Inliners and Hemmings)and they list the prefix as a 235. I haven't looked for the casting number yet.
I may be reading the chart incorrectly but DDA was the prefix on 1946 engines in 5100, 5400, and 5700 trucks. If that is correct, those trucks' standard engine was a 235.
POWER PLANT GENERAL INFORMATION
Serial Numbers - Engine - DDA
I looked again and did some more scraping. It is still obscured but I think it might be DBA instead of the DDA that I initially thought. So definitely a 216.
Hi all did some more checking and found the number on the top of the block to the back side of the distributor of "DAM 6066"...I can't find that code in the book, but the 839770 seems to put it in the 1946 year...any help would be appreactied.
The prefix on my '46 216 is DBA as well!!
It looks like 839770 might have been used on 216 blocks from 1942-1947.
Can you find date casting codes on the block and on the head?
http://www.1954advance-design.com/Web%20images/casting-code-photos/low-press-codes-ser-nums.html
