| | | Forums66 Topics128,049 Posts1,055,634 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 255 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 255 | Stovebolters; Was pulling the brake lines off of my 1950 3800 and stuck in the end of the line that runs between the main junction and the front junction there was a brass plug fused into the line's end. It looks like its there to prevent fluid from flowing back to the main junction. I haven't seen this item before, am I interpreting its use correctly? Any idea where a person might find a replacement? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | If you are able to post a link to a photo, that might help people speculate about what the part might be.
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | what Tim said for sure, a pic is needed - if there was anything anywhere to prevent return flow of the fluid, would the brakes ever release?
Bill | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | There should be nothing in that year ofm truck to stop fluid flow. | | | | | Joined: Sep 2011 Posts: 255 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 255 | Heres a link to a pic of the little brass plug. There are 2 more after it as well. Forgive the still ring around the base of the cone, this little plug is stuck in the line and I'm trying to free it with little luck. I wasn't sure whether, given that the master cylinder is below the brake lines, there might not be a little plunger that would prevent fluid from running back to the master. All I know is that this truck did have brakes that worked. Thanks! http://i1131.photobucket.com/albums/m545/carmental2/IMG_0798.jpgThanks - Bruce | | | | | Joined: Feb 2004 Posts: 29,765 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,765 | That's a brake shoe rivet. Somebody has stuck it into the brake line to block fluid from flowing to that wheel, probably because of a leaky wheel cylinder. That "fix" was not uncommon when someone wanted to get a disabled vehicle back on the road temporarily. Jerry
| | | | | Joined: Sep 2011 Posts: 255 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 255 | he he. Should have figured. Some of the lines running to the rear-end looked like they were commandeered from an old refrigerator. I guess necessity really was the mother of invention back on the farm. | | | | | Joined: Sep 2010 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2010 Posts: 59 | Mine was done similiar but the rear brakes were plugged. Then i figured out why when i pulled the drums off!
Daniel
1953 Chevrolet 3800 Stepside
| | | | | Joined: Sep 2011 Posts: 255 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 255 | Mine were in the same condition. I had extra thick pads made and got one last turn of the drums but I think this is their final go-round (pun intended).
On a related topic - my 1-ton has the park brake cable and brake assembly on only the passenger side, a patch of rubber has been bolted in place to cover the driver side hole on the flange plate. Did the 1950 1-tons always come with cable and brake for both sides?
| | | | | Joined: Sep 2010 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2010 Posts: 59 | Mine has the cables on both sides. But the levers were removed inside the drums on mine
Daniel
