5 members (Otto Skorzeny, Bill Hanlon, 48jim1ton, dt235sd, 1 invisible), 98 guests, and 2 robots.
Topics128,035
Posts1,055,556
#810058 12/24/2011 6:54 PM
I am trying to hook up a tach on my HEI distributor. I'm from the old school where it meant hooking to a coil. I see on the HEI where it should be hooked but I don't know how it hooks. I looks like it takes a special plug that I don't have and don't even know what to ask for at the parts house.
~Jim
If it is a stock 350 distributor it ought to take a regular old one of these.
Inside that hole in the cap, there's just a simple male blade connector. Just use the one pictured in the post above, and you're good to go! The signal to the tach works just like it would on a point-type distributor.
Well, I found the connector in my stash but can't see up into the slot where the male connect is. I guess I'll have to get a mirror.
~Jim
You can also find the OEM style plug/connector that will clip solidly into the distributor.
HEI Connector Example
SimS
SimS #810538 12/27/2011 3:29 AM
@BIG CHEVY 3600, Get a Accel #170072 connector plug. It has both wires and CANNOT be pluged in backwards. Run a 12 gauge switched hot to the RED wire to the red side of the plug and the green or blue (whichever they used when they made the plug,) to the signal wire from the tach. Unless your distributor is brand new, you will be amazed at the difference the HEI makes!
best wishes,
Les
Roadmarks #810660 12/27/2011 3:46 PM
You should be able to feel the spade connector with your finger tip. The wide part of the connector is parallel with the outside of the box.
That's correct. There should be 2, one beside the other.
Roadmarks #811124 12/28/2011 11:05 PM
If i'm not mistaken the HEI cap is actually marked which connection is which.
More pix on Flickr.
OK guys the plug came in from Summit today. After a while I'll light up the propane heater in the garage and see if I can hook it up. Thanks for the help. If this doesn't work I be back here begging for more help.
~Jim
