| | | Forums66 Topics128,088 Posts1,055,998 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2000 Posts: 90 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 90 | Hello. Who sells gear sets or adapters that would fit 1937-38 speedometer gear setup?
It appears that someone replaced the U-joint at the back of my 37 truck's transmission with a passenger U-joint (6-tooth speedo drive gear on shaft), but then put the 12-tooth truck speedometer driven gear back in. This setup ground up the teeth on the speedometer driven gear, since it wasn't a direct mesh with the passenger gear on the U-joint.
I have a good 19-tooth passenger driven gear that would work with the 6-tooth U-joint gear, but will need either an adapter or new set of truck gears to get the right speed on the dash.
1959 Chevrolet 3800 Pickup 1937 Chevrolet GC Panel Can you still call it a barn find if it's your barn? | | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | Check out this website: Scotts Speedometer See if you can talk to somebody that can help out. If the gears mesh and the speedo works, but is not correct, all you need to do get a GPS, record the speedo readings at 10, 20, 30, 40 and they can create an adapter to make it work.
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | |
