3 members (RonG, Forty9, Jon G),
126
Mod | | | Forums66 Topics128,163 Posts1,056,964 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2010 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 53 | rebuilding the front axle on my 54 3100 brake drum to brake drum.
i have read every post concering king pins that search brought up in the first 20 pages and did not find anything on the specs of the bores.
king pins have some play inside the axle bores, planning on going with the .01 oversized pins.
What size do i need to tell my machine shop guy to bore the axle bores to? is it the OD of the new king pin, or .001 larger or smaller than king pin?
also planning to do the loctite job to the new bushings in the spindles. i made a newbie mistake and got overspray in the spindle bores. any advise on how to get the paint out if paint thinner wont work? (dont want to use anything too abbrasive and hurt the bores)
only reason i put kinda urgent in the title is that i am wanting to order the parts tomorrow becasue the parts supplier has 10% off ending tomorrow
thanks -LGringo
'54 chevy 3100. In pieces now. .... I've always liked puzzles -Gig em Aggies! Class of 2013
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | NAPA used to list the diameters of the standard and .010 over king pin. I cannot tell if they still list the diameters because I am using a tablet computer and NAPA's handheld device interface gives limited information.
The Shop Manual that Kurt linked-to has the original king pin diameter at the end of the chapter.
| | | | | Joined: Jan 2011 Posts: 306 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 306 | take the pins, bushings, knuckles, and the axle to the shop they should know what needs to be done to make it all fit together correctly. if not i'd find another shop.
1963 c10 | | | | | Joined: Feb 2000 Posts: 5,229 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,229 | You want loose enough to go together, but tight enough to stay in the bore when you put the pin in. .002" to .005" should be plenty clearance in my opinion. As far as paint in the bores, they are going to ream them anyway so it doesn't matter. If you are real worried about it, take a little sand paper to them, you won't remove enough material to worry about once you sand through the paint. These are pretty forgiving, exact sizes doesn't matter all that much, just get them as tight as you can but still spin in the bore.
Joe
| | | | | Joined: Apr 2010 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 53 | As far as paint in the bores, they are reaming them anyway so it doesn't matter.
Joe only the bores on the spindles have paint in them. the spindles dont have to be reamed also right? only the axle bores? my spindle bores measure around 1.05 to 1.052 and the new OD on the bushings is 1.053. this is good enough tolerance for the bushings correct? (keeping in mind that the loctite 660 will be done on the bushings) machine shop guy prolly would know(or at least have an oppinion) but he is just a worker at a metal fab shop, not an axle shop. I was just wanting to get a second oppinion from yall's wealth of knowledge yall have on me. thanks a bunch -LGringo
| | | | | Joined: Feb 2004 Posts: 29,860 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,860 | You're asking about reaming the hole in the axle, not the spindle bushings, right? I like to use an expansion reamer, and cut & try until the kingpin is a firm push fit through the axle- - - -basically a "zero-clearance" fit. Another method would be to ream or bore the hole slightly undersize, and do the final fit with some type of hone. That's not really necessary, IMHO. If the steering knuckle bushings are the press-in type that need to be hone-fitted, I like to finish them off on a Sunnen power hone to as close a slip fit as possible. The alignment between the bushings is critical, in addition to individual diameters, so use a long piloted power hone. Jerry
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | | | | | | Joined: Apr 2010 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 53 | You're asking about reaming the hole in the axle, not the spindle bushings, right? I like to use an expansion reamer, and cut & try until the kingpin is a firm push fit through the axle- - - -basically a "zero-clearance" fit. Another method would be to ream or bore the hole slightly undersize, and do the final fit with some type of hone. That's not really necessary, IMHO. If the steering knuckle bushings are the press-in type that need to be hone-fitted, I like to finish them off on a Sunnen power hone to as close a slip fit as possible. The alignment between the bushings is critical, in addition to individual diameters, so use a long piloted power hone. Jerry that is correct, i am just needing to bore/ream the hole in the axle, not the spindle. in order to keep the alignment of the bushings good i will loctite them with king pin "installed" to keep the line. as far as the king pins themselves, i did not order them yet because i found that o'rielys can get them and are made in USA. they are about $40 more than the online supplier, but ill pay $40 for USA over chinesium. the part line at o'rielys is Rare Parts. anyone ever used them before? -LGringo
| | | | | Joined: Jul 2005 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 54 | At the top of the page is the heading "Tech Tips" in this section go to "suspension and steering" there you will find a well writin artical on king pins and floating bushings on half ton trucks. mtcw | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | I have bought the Rare Parts brand from O'Reilly's and directly from Rare Parts (I found them via a Google Search on an O'Reilly's part number). They let you into their catalog, even if you are not a registered vendor. http://www.rareparts.com/I do not know where they are made but they look to be very good quality (original-style tie-rod end). I used Hotrod's technique for over-boring an axle ( I wish I had known this technique before I guessed it). I used a brake cylinder hone to obtain the final tight fit (and, I froze the pins before installing the pins/assembly). | | | | | Joined: Apr 2010 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 53 | I have decided to do the reaming myself. I like that idea better, I'm trying to do most of the work myself, save money and more pride/satisfaction.
anyone have an opinion on brand or type of adjustable reamer to buy? (high-speed steel ,solid carbide, or carbide-tipped, straight flute or right hand flute)
thanks -LGringo
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | LGringo,
I will not be home until Monday, but I'll post the brand that I bought on eBay. It was an adjustable reamer that had a starting diameter to match the standard diameter. It cost me about $40 shipped.
| | | | | Joined: Feb 2004 Posts: 29,860 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,860 | For a 1/2 ton or a 3/4 ton, you'll need a straight-flute adjustable reamer, 27/32" to 15/16". It's available from ENCO, part #334-1113. My catalog is a few years old, but the price there is $20.21. Use lots of cutting fluid and ream a few thousandths at a time. You can always make the hole a little bigger. It's hard to put the metal back in there when you get it too big! use-enco.com http://www.use-enco.com/CGI/INSRIT?PARTPG=INSRAR2&PMAKA=334-1113&PMPXNO=946261Jerry
| | | | | Joined: Apr 2010 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 53 | Thanks for the replys guys. I'm excited about doing this myself. School took WAY too much time this semester ( guess it's for a good reason though  ) so not as much progress was made in the past few months as I planned. I am hoping to get this front axle back together before my Christmas break is over. Should be able to order a reamer Tuesday and get on with it. Thanks again for the help, I will be sure to post on how it works out (and then probably ask some advise on whatever task I take on next) thanks -LGringo
