0 members (), 166 guests, and 3 robots.
Topics128,081
Posts1,056,078
Members48,434
What sealant should I use on the 1/8 NTP to double flair brass adapters that are on the fuel pump and carb? I am refering to the casting to adapter connection. The sealant will have to hold up to gasoline. I do not like to use teflon tape.
JB
You are right not to use teflon tape as it does not hold up to gasoline. I believe plumbers "pipe dope" thread sealant will work. Just ensure you go sparingly so that none of it gets in the line.
But, sealant on the threads of a flared fitting really doesn't do much as the line will leak between the line and "nut"
Pematex #2.
DG
Denny G
Sandwich, IL
I've seen shreds of Teflon tape get into needle valves and jets, even internal passages in the carb at times, and cause all sorts of oddball mixture problems. I like to the "PTFE" (teflon) brush-on paste sparingly on pipe-thread fittings ONLY, and it's a good idea to leave the first couple of threads on the male fitting uncoated to be sure none of it gets into the fuel stream.
I used Rectorseal 5 pipe thread sealent and it worked well.It says on the tube "for thrreaded metal and PVC pipe formulated for potable water, natural gas and a wide variety of fluids and gases." .
[url=http://www.stovebolt.com/gallery/shannon_joe_1953.html]1953 Chevy 3100[/ur When life looks like easy street there is danger at your door
