8 members (57 Drifter, Bill Hanlon, 3B, Gdads51, Otto Skorzeny, Gray_Ghost, DennisM, rick46ia),
45
Mod | | | Forums66 Topics128,022 Posts1,055,362 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#81016 08/04/2007 11:49 PM | Joined: Dec 2006 Posts: 37 Member | | Member Joined: Dec 2006 Posts: 37 | Hey, what do you guys use as head bolt sealer on a SB chevy? would c5a work? thanks in advance. | | |
#81017 08/05/2007 12:12 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | 51dan79,
I remember wire brushing them, dipping them in oil and sticking them in. None ever leaked...maybe we're talking different head bolts.
Stuart | | |
#81018 08/05/2007 12:29 AM | Joined: Dec 2006 Posts: 37 Member | | Member Joined: Dec 2006 Posts: 37 | Of all the motors we did as kids to now [50 years] we did the same, now I decide to read the literature from world heads and they say you need a sealer, I think I'll just do like we always did and oil them. thanks Dan | | |
#81019 08/05/2007 12:40 AM | Joined: Jan 2007 Posts: 176 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 176 | I use a little pipe thread sealer, just a dab. although on a smallblock it is probably not nessary. on the newer engines of today with aluminum blocks and steel fastners it is nessary
1970 C50 dump! saving orphans from the CRUSHER
#81021 08/05/2007 1:33 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Dan,
I went to World Heads, and sure enough, in big bold print, it says to use a thread sealant. They make the stuff, so I sure would go with their advice...call them and ask them what they recommend. I thought all small block head bolt holes went into the water jacket...maybe they don't!
Stuart | | |
#81022 08/05/2007 2:23 AM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I would say the real question is whether or not the bolt holes in question are blind tapped or open on the bottom. I use either Fel-Pro Pli-A-Seal or Permatex high temp thread sealant (the white stuff). From-A-gasket is ok, but will dissolve in gas, so be carefull where you use it. If they're blind tapped, use a engine oil,or anti-seize if it's going into aluminum.
Bill Burmeister | | |
#81023 08/05/2007 2:57 AM | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Permatex #2 is good for tapped holes in to water jackets. | | |
#81024 08/06/2007 9:14 AM | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | on SBC's I have always just lubed the head bolts for proper Tourqe..now on the Intake I always use the white permatex thread sealant on ALL as some of the bolts do go into the water jacket . my 2 pennies. Tim | | |
#81025 08/07/2007 5:17 AM | Joined: Mar 2006 Posts: 72 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 72 | Never used a sealer on SBC head bolts. Just lubed 'em and torqued 'em. If you were looking to seal something, I'd recommend Permatex #2. | | |
#81026 08/07/2007 3:11 PM | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | I assemble most engines with NeverSeez thread lube, unless the factory service manual calls for a thread sealer. Then I use Permatex Super 300. It's a brush-on sealer that's a thick liquid, somewhat easier to apply than the stuff in the tube. There's also another brush-on liquid Permatex product called 3-D, but Super 300 is compounded to be resistant to things like alcohol and aviation gasoline, so I think it's a better sealer. It's a little hard to find unless you're ordering from a Permatex distributor. Jerry
#81027 08/09/2007 5:20 AM | Joined: Jul 2003 Posts: 586 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 586 | I've used Permatex White thread sealer on 6 or 7 engines i've done. Never had a problem. Cecil........ | | |
#81028 08/09/2007 11:24 AM | Joined: Nov 2004 Posts: 117 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2004 Posts: 117 | I think C4A would be a good choice (ha). Never used thread sealer on a head bolt before, don't know why now.
cgresham1212 If you don't drive it, why have it? 55 1st Series 3100 5 window
