7 members (wilbur53, Rusty Rod, D B Cooper, RaNfLaS, Gdads51, KEVINSKI, 1 invisible),
114
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,094 Posts1,056,060 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2011 Posts: 23 New Guy | | New Guy Joined: Dec 2011 Posts: 23 | Just tryed to install new vacuum advance on my distributor. While engine is off every thing moves freely. Once engine is started I can see advance mechanism attempting to adjust but seems awkward. I think I may be just missing something during set up. Also the original unit which was removed required me to unhook dist lock ring and swing 90deg., new one I had to install a #8 machine screw and a nylok nut with a spacer between mounting bracket and dist lock ring I did not tighten down just a lil slack. Any ideas?
| | | | | Joined: Dec 2011 Posts: 23 New Guy | | New Guy Joined: Dec 2011 Posts: 23 | I see views but no replys. I have heard of the petronix ignition, I have installed these on other dists by replacing plate inside dist, is this an option or do I replace complete dist. I just can't give up on old dist this easly. I guess its a guy thing. Has anyone else dealt with similar issue. Is there a difference in brackets on dist or dif vacuum advance units(cars-trucks)? | | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | If the new unit is not like the old unit, and you know the old unit worked, I'd start there as the culprit. Can you post some photos of what you're seeing? That will help us help you.
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | It sounds like you got an incorrect replacement unit. Why not go back to the properly-fitting OEM part? I see them on Epay all the time, and quality parts vendors like NAPA can probably get the correct part. Stay far away from the mouth-breather computer jockeys at places like Auto Zone for old stovebolt parts!
Edit: Check your IM inbox- - - -I found the correct unit on Ebay Jerry
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I see views but no replys. I have heard of the petronix ignition, I have installed these on other dists by replacing plate inside dist, is this an option or do I replace complete dist. I just can't give up on old dist this easly. I guess its a guy thing. Has anyone else dealt with similar issue. Is there a difference in brackets on dist or dif vacuum advance units(cars-trucks)? Pertronix makes a few different units for a 235 engine. There are 6v and 12v units; and, there are units for the older shorter-cap distributor and the newer taller-cap distributor. | | | | | Joined: Jan 2004 Posts: 188 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 188 | I got a vac-adv for my '54 from one of the truck supply places. It had a sort-of "key shaped" post to engage the link on the distributor. That was not correct for my unit.
I went to a different supplier and got one with the correct link for my distributor. It used a screw with shoulder to engage the link on the distributor.
I don't know which years use these two different kinds of linkage. | | | | | Joined: Dec 2011 Posts: 23 New Guy | | New Guy Joined: Dec 2011 Posts: 23 | Yes my orig is the key shape type, the new has hole which would need screw type mtg., they look identical other than that. My truck is a 55 second series. I have no clue as to which type truck originaly came with but I would like to keep with what was there. I viewed im posts as to ebay source for correct unit. Box looks old and I worry that diaghram is old and cracked now or fail soon. | | | | | Joined: Jan 2004 Posts: 188 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 188 | The vac-adv I got from Classic Parts had the "key shaped" post for the link. If you order from them, ask them to verify that visually before you confirm the order. They have always been very helpful with my orders. | | |
