4 members (GrandpasJimmy, Shade Baby, 78buckshot, Woogeroo), 90 guests, and 2 robots.
Topics128,186
Posts1,057,322
Members48,469
#81016 08/04/2007 11:49 PM
Hey, what do you guys use as head bolt sealer on a SB chevy? would c5a work? thanks in advance.
#81017 08/05/2007 12:12 AM
51dan79,
I remember wire brushing them, dipping them in oil and sticking them in. None ever leaked...maybe we're talking different head bolts.
Stuart
#81018 08/05/2007 12:29 AM
Of all the motors we did as kids to now [50 years] we did the same, now I decide to read the literature from world heads and they say you need a sealer, I think I'll just do like we always did and oil them. thanks Dan
#81019 08/05/2007 12:40 AM
I use a little pipe thread sealer, just a dab. although on a smallblock it is probably not nessary. on the newer engines of today with aluminum blocks and steel fastners it is nessary
1970 C50 dump! saving orphans from the CRUSHER
#81020 08/05/2007 1:27 AM
Permatex form-a-gasket #1
http://www.permatex.com/products/au..._Permatex_Form-A-Gasket_No_1_Sealant.htm
This is what I was taught years ago and still use today.
#81021 08/05/2007 1:33 AM
Dan,
I went to World Heads, and sure enough, in big bold print, it says to use a thread sealant. They make the stuff, so I sure would go with their advice...call them and ask them what they recommend. I thought all small block head bolt holes went into the water jacket...maybe they don't!
Stuart
#81022 08/05/2007 2:23 AM
I would say the real question is whether or not the bolt holes in question are blind tapped or open on the bottom. I use either Fel-Pro Pli-A-Seal or Permatex high temp thread sealant (the white stuff). From-A-gasket is ok, but will dissolve in gas, so be carefull where you use it. If they're blind tapped, use a engine oil,or anti-seize if it's going into aluminum.
Bill Burmeister
#81023 08/05/2007 2:57 AM
Permatex #2 is good for tapped holes in to water jackets.
•1952 Chevrolet 3800 pickup
---All pictures---
#81024 08/06/2007 9:14 AM
on SBC's I have always just lubed the head bolts for proper Tourqe..now on the Intake I always use the white permatex thread sealant on ALL as some of the bolts do go into the water jacket .
my 2 pennies.
Tim
1952 Chevy Shortbed
Photos in Photobucket
#81025 08/07/2007 5:17 AM
Never used a sealer on SBC head bolts. Just lubed 'em and torqued 'em. If you were looking to seal something, I'd recommend Permatex #2.
1947 Chevy 6400 Wrecker
Old Stovebolts don't leak oil
They just mark their territory
#81026 08/07/2007 3:11 PM
I assemble most engines with NeverSeez thread lube, unless the factory service manual calls for a thread sealer. Then I use Permatex Super 300. It's a brush-on sealer that's a thick liquid, somewhat easier to apply than the stuff in the tube. There's also another brush-on liquid Permatex product called 3-D, but Super 300 is compounded to be resistant to things like alcohol and aviation gasoline, so I think it's a better sealer. It's a little hard to find unless you're ordering from a Permatex distributor.
#81027 08/09/2007 5:20 AM
I've used Permatex White thread sealer on 6 or 7 engines i've done. Never had a problem. Cecil........
#81028 08/09/2007 11:24 AM
I think C4A would be a good choice (ha). Never used thread sealer on a head bolt before, don't know why now.
cgresham1212
If you don't drive it, why have it?
55 1st Series 3100 5 window
