1 members (TexasA&M48Truck), 67 guests, and 3 robots.
Topics128,082
Posts1,055,964
Members48,430
I just got a 235 manifold assembly to replace the 216 assembly on my 235 and noticed the anchor pin for the heat riser spring is broken off. Has anyone had this problem along with a solution? Could a piece of steel rod be welded back in place?
Allan
1951 GMC 1/2-ton
Two 1953 Chevy 3100 5-window
Thanks Tim, but I'm referring to the small anchor pin that the curved end of the spring clips over, as shown in one of Gus' photos.
pic
Allan
1951 GMC 1/2-ton
Not sure this is the way to do it but if its off the engine I"d grind it down flat, then drill a hole and put a roll pin in its place. I think you can drill deep enough for a roll pin to hold it without drilling all the way through it....just me thinking again!
Big Bolt Forum Co-moderator
Hey Alvin, that's what I would do too.
1948 Chevy 2-Ton
That's a good idea and it's what I attempted to do, but the original pin must be hardened steel and I could hardly make a dent with my titanium coated drill bit. I'm going to take it to our local machine shop and see what he can do.
Allan
1951 GMC 1/2-ton
I took the manifold to our local machine shop and he drilled out the old pin and inserted a new one for $20...problem solved.
Before
After
Allan
1951 GMC 1/2-ton
...isn't it nice when you feel you get your money's worth with a good job. Thats cheaper than breaking a couple drill bits and driving to town to get more!!
Nice job.
