Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (jmoore, frogfarmer, Jon G), 105 guests, and 4 robots.
Topics128,288
Posts1,058,574
Members48,492
#809821 12/23/2011 11:58 PM
Hi all…I just bought a mostly restored 46 ¾ ton pickup and found out that it looks like I may have a small leak in the rear freeze plug on the back of the block. I am looking for some advice to stop the leak, rather than pull Transmission off and replace the plug. Several friends (I hope) said to buy some good radiator stop leak a mix it with the coolant. Any problems with that or is there a better solution.
Thanks…John
jkully #809824 12/24/2011 12:07 AM
Stop leak is a band-aid. If one is rusted through others can't be far behind. Might as well do it right the first time.
jkully #809841 12/24/2011 12:40 AM
Stop leak is good stuff. Try it. It's cheap. If it doesn't fix the problem, not much lost.
I agree with Cletis though, that if the problem is rust-through, it may not work, or will work only for a short time.
Kurt
Kurt_51carryall #809851 12/24/2011 12:50 AM
1 Offline
If you do replace the plugs make sure they are made of brass, not steel.
Daniel
1953 Chevrolet 3800 Stepside
1953redchevy #809867 12/24/2011 1:19 AM
Thanks all...I'll try Stop leak...if it dosn't work I won't have lost much...I will replace them all with Brass ones later in 2012...Thanks again...
Merry Christmas & Happy New Year
