1 members (51sub),
187
7
Mod | | | Forums66 Topics128,288 Posts1,058,578 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2011 Posts: 40 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 40 | Hi all…I just bought a mostly restored 46 ¾ ton pickup and found out that it looks like I may have a small leak in the rear freeze plug on the back of the block. I am looking for some advice to stop the leak, rather than pull Transmission off and replace the plug. Several friends (I hope) said to buy some good radiator stop leak a mix it with the coolant. Any problems with that or is there a better solution.
Thanks…John
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Stop leak is a band-aid. If one is rusted through others can't be far behind. Might as well do it right the first time. | | | | | Joined: Aug 2011 Posts: 835 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 835 | Stop leak is good stuff. Try it. It's cheap. If it doesn't fix the problem, not much lost.
I agree with Cletis though, that if the problem is rust-through, it may not work, or will work only for a short time.
Kurt | | | | | Joined: Sep 2010 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2010 Posts: 59 | If you do replace the plugs make sure they are made of brass, not steel.
Daniel
1953 Chevrolet 3800 Stepside
| | | | | Joined: Dec 2011 Posts: 40 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 40 | Thanks all...I'll try Stop leak...if it dosn't work I won't have lost much...I will replace them all with Brass ones later in 2012...Thanks again...
Merry Christmas & Happy New Year | | |
