1 members (Hotrod Lincoln),
72
0
Mod | | | Forums66 Topics128,049 Posts1,055,680 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2011 Posts: 23 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 23 | So i have settled on a 1954 GMC truck. I want to go total resto but with a few modern changes. This is my first truck and was wondering if anyone has taken one from 6 vlt to 12vlt and what i needed to do? Is it difficult? | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | read here, and as you're not far from him, talk to Patrick in Casa Grande  Bill | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | 6 volt starters will work with 12 volts if you don't crank too long. I prefer installing 12 volt field coils. Your 54 should have a 6 volt, 6 bolt flywheel which is a very much sought after item. You could probably trade for a 12 volt flywheel and starter and possibly get a little money out of the deal on top of it. | | | | | Joined: Dec 2011 Posts: 23 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 23 | Thanks man i am a lost soul with this truck. So many options | | | | | Joined: Dec 2011 Posts: 23 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 23 | | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Ive been running a 6volt starter with a 12volt system for 21 years now,with no troubles.
Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
