8 members (EchoBravoSierra, Gdads51, LAROKE, frogfarmer, klhansen, Hotrod Lincoln, 2 invisible),
162
Mod | | | Forums66 Topics128,198 Posts1,057,269 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | Would the intake manifold on a 41 be painted the same color as the engine, in an original configuration. Dave 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Intake, exhaust damper, water pump and stat housing, bell housing, spark plugs were installed when the engine was painted.
So they would all be dark gray and the The Filling Station engine paint is very close due to the research they have done.
DG
Denny G Sandwich, IL
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | As a side note. In the "Pictorial History of Chevrolet 1940-54" there is a picture of the 1947 engine assembly line. It appears that a black starter was installed before the grey engine paint went on. It looks like a fair amount of grey got on the starter.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | if your talking about the 41 gmc then it is olive green. the closest over the counter spray is krylon #3541 "Hosta Leaf" green. jim carter has the green also but is quite thin. they both look good | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Think you could post that picture Dave???
dg
| | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | My problem most is the parts place won't or can't ship paint to AK so I'm just going to have to use something close,anyone have any suggestions in a name brand paint? I am talking engine color now. Dave 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | That's not really a problem Dave, most any enamel will work just fine for engine paint. For some reason people think they get real hot and that they need high temp paint. They don't, just look at your temp gauge, the only really hot spot is around the exhaust ports. You could use good old Rustoleum smoke gray and darken it with some black or better yet some dark navy blue. Biggest thing is getting it surgically clean before you apply the paint. As with the new engines from the factory back in the day, the paint on the exhaust will burn off after a short time.
Denny Graham Sandwich, IL
| | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | Thanks, guess that's what I'll do. My engine is at the machine shop right now and I have to assemble it then think about paint. Dave 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | As for paint I use Rust-Oleum Charcoal grey. It is close enough for me. Pic of engine
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | that looks great, good enough for me, I'm not doing an original restoration anyway, I'm putting a 235 in my 41, I don't even think I'll try and disguise it. Not to many will know the difference anyway. Dave 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Mar 2001 Posts: 629 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 629 | Great reference photos!!!
Tim Sheridan 1947 First Series Chevy 1/2-Ton"Liberty Series" - "Art Deco" - Whatever you'd like to call it. In the Gallery | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Thanks for the pictures Dave, I dropped the hint that it would make a welcome Christmas present, the book you got those out of that is. It looks to me that what may appear as over spray on the starter is simply reflected light. I’d stake my life on the starter, generator breather pipe, distributor and horn as being installed after the engine was painted and them always being painted black. I’ve never seen an original starter with any gray overspray on it.
Rustoleum has gone thru some major expansion over the last decade. Where they only offered the one line of “Rustoleum, stops rust” enamel years ago, they now have a dozen different lines each having a dozen different textures and colors. I’ve used Rustoleum ever since I was a kid back in the 40’s. My dad and brother were always dragging home old machinery and restoring it for the shop and the paint of choice was always Rustoleum Smoke Gray or as it is often referred to, machinery gray or battle ship gray. I see now that they have a light and dark gray in their automotive line of acrylic enamels. I’ll have to see if I can get a sample of the dark gray and compare it to The Filling Station engine gray which I swear by since I‘ve matched it up to several original Chevrolet engine parts that still had there paint intact.
Getting back to Homer, I don’t know how much of the Rustoleum product line is available to Dave up there. I get the impression that Homer is sort of isolated from the rest of the world?
| | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | We are not at the end of the world, BUT you can see it from here. We are at the end of the road BUT, we are not an isolated community, we have a Mcdonalds, Napa CarQuest Safeway. The problem is getting paint shipped, we can get most anything but the specialty stuff coming from the venders because of the hazardous shipping exclusion. That is why I'm also trying to find a good paint code for my 41 to get the proper(or close)paint for the cab and the interior. I talked to a powdercoating guy up the road today and he has a high temp product, I think I'll try it on the intake and exhaust manifolds, time will tell. Dave
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | My nephew took an old crashed USAC Silver Crown car an rebuilt it so it is street legal. He has a 350 small block in it and had the headers powder coated with the high temp silver and it’s held up really well for several years now.
