3 members (Joe H, Bill Hanlon, Phak1), 118 guests, and 3 robots.
Topics128,127
Posts1,056,681
Members48,452
I am putting together a suburban with parts from other trucks. What is the differences between the front axels and their corresponding parts? I am talking about spindles, drag links and the such. Can anyone tell me what to look for when buying the correct parts so I don't buy the wrong thing again? thanks
3B Offline
Hy GMONIZ, according to my Canadian parts book, the front axle is the same for the 1/2 tons from 1941 to 1955 "A" or first series. The same holds true for the spindles, the drag links are the same 1947 to 1952, then 1953 to 55 "A" or first series, hope that helps.
What is the difference? I thought that the front spindles changed too when they went from Huck brakes to Bendix, something about the diameter of the spindle. I could be wrong, but I think they have different bearings.
thanks for the input.
No difference. They were all the same AND to show you how much more confusing it can be, 49-54 car brakes, bearings and hubs will also fit the 41-54 truck fron axle.
So, what's the difference on the drag links? Was this just a parts number change? I have to gather up the parts and I have already bought some things wrong, I just don't want to do it again. Thanks
ODSS Lawman
ODSS Lawman
The difference in the drag links are how they attach to the pitman arm and the steering arms. Earlier type require a ball fitting be pressed into the pitman and steering arms and the draglink has a socket this fits on to.
The later draglink has pins or dowels like a modern vehicle and the pitman and steering arms dont have the ball fitting just a hole.
The important item once you decide which to use is to have matching arms to go with it.
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
The spindles had different size holes where the backing plate attached, when the brakes went from Huck to Bendix. You can check the bearing IDs and ODs from the parts books. I know that on the one Ton, there were bearing changes through the AD years.
1951 1 Ton Completed
Thanks guys, now I will look for pictures to make sure I don't end up with more extra parts!
