2 members (68ironhead, stlcardinalsguy), 187 guests, and 14 robots.
Topics128,078
Posts1,056,036
Members48,433
#80757 08/02/2007 2:01 AM
Going to rebuild the carburetor now that I've got the gas tank sraightened out (no more rust!) and I'm trying to figure out what carb I have.
Based upon Carbking's website , I should have a number stamped into the bottom of a Carter W-1 (which I'm pretty sure I have).
That number appears to be 503. It's a little hard to see it, though.
I can't find that number on any list.
It's a carter, and it's cast iron. Anyone got any ideas?
Thanks in advance!
Okay, I've had another look.
It's definitely a W-1. I found it cast into the outside of the unit.
The number on the bottom, after closer inspection with a trouble light and a magnifying glass is actually 603.
I'm still not sure what the heck this thing really goes to...
This may be a question for carbking.
Originally posted by carbking:
"Workmaster - the 603 is a "code" number. Carter knew that the commercial rebuilders would throw away the tags, and stamped their carburetors with a code. The code list was given to the Carter distributors. 603 means 684s."
I have the same carb. Carbking helped me identify it as a Carter W-1 manufactured for 1949. It is a unique entity within the Carter W-1 line. Try the search function for more info. Hope this helps.
1948 AD Pickup
I was afraid of that... eek
Thanks for the info.
At least my accelerator pump is still good. All I really need is a "cleanup" kit with gaskets and ball valves. A little carb cleaner and it should be right as rain.
I'll start looking for a 574, though... grin
Yeah, when I changed over to the Rochester, I rebuilt my W-1 before I retired it to a box over 25 years ago. It came out of the box a couple of weeks ago and I dutifully took it apart for inspection and re-cleaning before installation. I was surprised to see that the pump leather was still perfect. SO far so good - runs like a champ. My thanks to carbking for his guidance.
1948 AD Pickup
