3 members (Hotrod Lincoln, OlderBlue, JeffA), 159 guests, and 3 robots.
Topics128,162
Posts1,056,938
Members48,458
Does anybody know of a good wiring harness that is available for less than 450.00 ?? The Rhrode Is. people do good work..but are pretty pricey..any info on another co. out there, only one talight on my Suburban..other than that the wiring is pretty simple..thanks Bruce
1936 Chevy Suburban Carryall
1941 Chevy Woodie with Cantrell body
1936 Low Cab Chevy Pickup
1941 Spec Deluxe Chevy Coupe.
1953 Pontiac Catalina hardtop
More pix on Flickr
Bruce, ALL the perfect stuff is pricey. I have a YnZ harness in my 46 it's great but expensive. If you have the time, patience, and motivation you could build your own if you have your old harness as a pattern. I've seen photos of how these shops build a harness; get an original, lay it out on a sheet of plywood, disect it like an archeologist and copy. I'd check with Jim Carter's in MO or The Filling Station, see what they have. Best of luck- Jim http://www.ynzyesterdaysparts.com/
WOW that's a rare piece you have, better start eating your Wheaties!!!
1946 1/2-Ton Chevy
Ex Hall Monitor
Ex Hall Monitor
Indeed! What a cool truck.
