| | | Forums66 Topics128,174 Posts1,057,048 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 205 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 205 | Does anybody know of a good wiring harness that is available for less than 450.00 ?? The Rhrode Is. people do good work..but are pretty pricey..any info on another co. out there, only one talight on my Suburban..other than that the wiring is pretty simple..thanks Bruce | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Bruce, ALL the perfect stuff is pricey. I have a YnZ harness in my 46 it's great but expensive. If you have the time, patience, and motivation you could build your own if you have your old harness as a pattern. I've seen photos of how these shops build a harness; get an original, lay it out on a sheet of plywood, disect it like an archeologist and copy. I'd check with Jim Carter's in MO or The Filling Station, see what they have. Best of luck- Jim http://www.ynzyesterdaysparts.com/WOW that's a rare piece you have, better start eating your Wheaties!!!
| | | | | Joined: Aug 2005 Posts: 6,378 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,378 | WOW that's a rare piece you have, better start eating your Wheaties!!! Indeed! What a cool truck.
