0 members (),
102
Mod | | | Forums66 Topics128,186 Posts1,057,319 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#80748 07/31/2007 4:06 PM | Joined: Sep 2006 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 127 | what is the difference between the two? would it be possible to make a 235 into a 261 by changing the crank or bore? I know the 261 is highly desirable...what about the blue flame engines? My 51 is my daily driver and I live in the mountains of colorado... I want to keep a straight 6.. suggestions and info would be great
"I'd rather have a bottle in front of me than a frontal lobotomy." -D. Parker 1951 Chevy 3100 | | |
#80749 08/01/2007 6:39 AM | Joined: Nov 2005 Posts: 5 Junior Member | | Junior Member Joined: Nov 2005 Posts: 5 | In my '51 I have taken a 1954 261, bored 30, shaved the head 20, mild cam, balanced, polished the intake, twin carbs, offie water heated intake manifold, Fenton split exhaust, 5 sp with .373 rear gears. It's "this" close to firing up time to go to the muffler shop. Once I take the test drive I'll post my smiles, I hope.
This is my first time to be this involved with the "nuts & bolts" of any vehicle. I'm learning as a hands on finisher. Best thing that I have ever done. Now when I look at other projects I KNOW the love that's in the project.
Lloyd from Washington | | |
#80750 08/01/2007 6:47 AM | Joined: May 2004 Posts: 920 'Bolter | | 'Bolter Joined: May 2004 Posts: 920 | Hey Mike, start with this. www.oldchevytrucks.com/Tips/261_six.htm Then do a search using "261" here and you will find tons of info. Lloyd, that's great. Keep up the progress report. I'm doing the same build as you pretty much only my tranny is an sm420 w/ a Gear Vendors O.D. and the original 3:90 posi. I have yet to assemble the motor, but the machine shop work including the balancing is done. | | |
#80751 08/01/2007 11:43 AM | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | The 261 is a little more powerful with 148 hp vs. the 140 from the 235. | | |
#80752 08/01/2007 3:54 PM | Joined: Sep 2006 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 127 | basically I just wanted to know if the block was the same, would it be possible to "make" a 261
#80753 08/01/2007 5:11 PM | Joined: Sep 2006 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 127 | ok now I have a clue, I read the history on the 261.. I may have to dig one up
#80754 08/01/2007 9:34 PM | Joined: Jul 2003 Posts: 132 'Bolter | | 'Bolter Joined: Jul 2003 Posts: 132 | From experience I can tell you, NO. Not enough material in block to bore it that far.
Leaks water when you fire it up. DAMHIKT!!! | | |
#80755 08/01/2007 10:45 PM | Joined: Nov 2004 Posts: 117 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2004 Posts: 117 | The 235 and 261 blocks are different. They both share the same crank; however, the 261 has beefier rods. Sorry, but you cannot bore a 235 block to a 261.
cgresham1212 If you don't drive it, why have it? 55 1st Series 3100 5 window
#80756 08/01/2007 11:03 PM | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | n case you are interested, the 261 high-lift cam can be used in a 1954 and later 235 (as used in the 53/54 Corvette Blue Flame Six). This would supposedly give higher power output at higher engine speeds. Use an "848" head for higher compression and you would have a peppier 235. | | |
