1 members (Dusty53),
174
Mod | | | Forums66 Topics128,101 Posts1,056,180 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | A fender cover disappointment! Well, I’ve been waiting for two and half weeks for these fender covers from Classic Parts of Am. Finally got here today, the reason I wanted these was because they were listed as being wider than the ones from the auto parts (NAPA) and should protect the fat fenders on an AD from belt buckle rash. The one from NAPA was nicely made, two layers of smooth vinyl with the edging sewn up around the outsides and magnets sewn into the top flap that holds it to the fender, the only problem with them was they were just to short. The two that I got today from Classic Parts are really a disappointment, all they are is a sheet of soft foam rubber with the GM logos silk-screened on them. Had I known that was what they were going to be I simply would have ordered a full width sheet of extra soft foam rubber from McMaster Carr and cut my own to what ever shape and size I wanted. http://www.pbase.com/dennygraham/image/140350844/large So why for the post? Just wanted to give a heads up to anyone thinking of ordering one of these. If you think by the picture that your getting a high quality fender cover from the vendor, at least this vendor, forget it, save your self a buck and buy some raw material and roll your own, it’ll be just as good if not better. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Thank you Denny. I/we can always count on you for a true assesment of things you try. Is priceless information. I have a pennzoil cover I've had for years that is pretty nice...but short for the fenders as you mention. I have a couple moving blankets that have been nice to me. I have more than one. Some for fenders only and some to lay down on. I bought them on sale at Harbor Freight, with a coupon for $4.99. The local Northern Tool store has some "on sale" now for $5.99 that are 72x80 and are a little thicker than the cheap H.F.
Its just hard to find good QUALITY anymore. One thing for sure, I won't be buying a fender cover from C.P. | | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | Just kick the da*% cat!!! | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Denny,
Thank you for the report. I have a 12 year old fender cover from Chevy Duty (Classic Parts) and it is not at all the same as the one you describe.
Nonetheless, I use the HF small mover's blanket described by Alvin.
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Yeah, I've used old bedding blankets and moving blankets. In fact one of my favorite things to use even today is a fender cover that followed me home about 50 years ago when I worked in a Chevy dealership. It's big, big enough to cover any fender and made from a soft fluffy tan fabric, the only problem with the fabric covers is they tend to slip around and slide off the fender. That’s why you see the rubber/vinyl ones in the commercial garages today, they don‘t slip around.
The one from NAPA was made like the ones you see in the dealerships. One of the things that I liked about it was the magnets at the top that hold it tight to the inner fender flange on the AD’s, but they're just way to small. These well made covers are available in larger sizes and custom made but the big ones are up near a hundred bucks.
You wouldn’t think that a lousy fender protector would warrant this much concern but when you spend as much time under the hood of your old truck as a lot of us do, you want something that you’re comfortable with. It’s like that feeling you get when you climb into a pair of those old well worn Levi’s.
DG
| | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | Hey Denny, Why not make some pockets to slide some magnets in your moving blankets. That way they won't slide around. I bought some small square magnets at Harbor to use to test metal for critical temperature when making tools in the forge. I couldn't find them on their webpage, but here are some http://www.harborfreight.com/10-piece-craft-magnet-discs-98405.html. A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Sep 2007 Posts: 461 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 461 | I like the higher quality moving blankets as well Denny. Even clamp them in place when necessary. Be carefull with magnets, they can pickup small shavings or filings that could scratch up the paint surface.
| | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | Dang,, that's true. Never thought about the magnets picking up shavings. Guess it would have to be something sewing on suction cups. I did a google and came up with this: http://www.1000bulbs.com/product/21...777206SBWINMNT&site=www.shopping.com A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ...or maybe a couple "loops" sewed onto the edge of it that you could "hook" onto something?? There I go, thinking again! | | | | | Joined: Apr 2004 Posts: 438 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 438 | Speaking of shipping blankets, I've found that a good Army/Navy supply outlet aways has good, cheap, soft, blankets to be used for whatever.  | | | | | Joined: Sep 2010 Posts: 49 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2010 Posts: 49 | I was going to buy a fender cover but I took a rug out of the house. It works great. It has rubber on the back side to keep it from sliding & I had a choice of size until I got the first one. | | | | | Joined: Sep 2007 Posts: 461 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 461 | Husker, I will vote for whaterever.
