4 members (Fannin, Phak1, TUTS 59, 1 invisible), 180 guests, and 2 robots.
Topics128,084
Posts1,056,085
Members48,434
#806880 12/15/2011 1:09 AM
my 3800 has a bent tie rod. will a 3/4 ton fit as a replacement? I can't seem to find one for a 1 ton.
Any suggestions.
Thanks, Mike
mike49 #806891 12/15/2011 1:36 AM
3B Offline
Hy mike49, welcome, it is always helpful for answering questions if the person asking the question tells us what year of truck he/she is asking about. Most tie rods are the same 3/4 ton and 1 ton, but if you give us the year we can confirm.
3B #806947 12/15/2011 4:00 AM
Hi, it's a 1949 chevy 3800. I've only had it 1 month and am trying to clean up some of the issues like steering slop, seat belts, adding an oil filter. My son and I were working on it today and discovered quite a kink in the tie rod. The ends seem good but the rod flexes while steering hence the needing to replace. I've checked the catalogs and can only find 1/2 & 3/4 ton parts.
I'm hoping the 3/4 T will be acceptable replacements.
Thanks again.
Mike
mike49 #806975 12/15/2011 5:23 AM
On my '54 2-ton, I took the tie rod to a machine shop that straightened it.
I walked in with it, he took it to his press and 10 minutes later I walked out with a nice straight part.
The 3/4 and 1 ton tie rods are completely different. The 3/4 ton tie rod is a solid rod with 3/4-16 threads. The 1-ton is a hollow tube with 13/16-18 threads on the inside and is the same on both the 1 & 1-1/2 tons.
These 2 different tie rods are used from 46-55 (early) according to the '59 parts book.
The complete tie rod w/ends from a 1-ton can be used to upgrade the smaller trucks to the newer style tie rod ends.
'38 Chevy 1-1/2 ton
'49 Chevy 1/2 ton
'54 Chevy 6400 2 ton
'55.2 GMC 3/4 ton
'56 GMC 1-ton
No Room Left in Shop
OlBlue #807014 12/15/2011 9:59 AM
What do you mean by newer ends? Yes the rod does seem to meet the dia you mention vs 3/4" of the 3/4 T. I did not realize the 'rod' was really a tube. I will check that out in the AM. What do I need for replacement ends on the tube you mention? This is my 1st old truck and am new at all this.
Thanks so much.
Mike
mike49 #807038 12/15/2011 2:44 PM
Mike,
The smaller trucks used a solid tie rod with ends that fit over a ball on each steering arm. These ends are adjustable for fit on the ball.
The bigger trucks used a hollow tie rod and the ends screwed into the rod. The ends themselves have a tapered stud that bolts to a corresponding hole in the steering arm. These ends are not adjustable.
'38 Chevy 1-1/2 ton
'49 Chevy 1/2 ton
'55.2 GMC 3/4 ton
'56 GMC 1-ton
mike49 #807066 12/15/2011 4:00 PM
I think I have an extra 1 ton tie rod if you still need one.
Bruce
My Trucks
Stuff I Collect
Thanks for the offer, Let me crawl under and check mine out first.
Thanks again, Mike
mike49 #807198 12/15/2011 10:34 PM
up date. The tie rod appears to be solid and threaded on the end, approx 3/4" dia. and 43-44" long. I'd send photos but can't figure out how.
Thanks, Mike
mike49 #807452 12/16/2011 6:40 PM
I swapped in a 1 ton tie rod and ends for my 53 3/4 ton as with the modern ends you get a bit more space between end and tire. I big issue if you are using radial tires.
1946 1/2-Ton Chevy
Moderated by  Dusty53
