9 members (Gdads51, Shaffer's1950, 78buckshot, Phak1, Leo, dt235sd, Jon G, mick53, 4tttt8), 87 guests, and 4 robots.
Topics128,181
Posts1,057,180
Members48,465
guys, i waqs told by a old man mechanic that my 48 loadmaster low oil psi 235 when shes runnin has a "slight" ticking from the lifters is normal as its a solid lifter engine, is this true? i means its really slight ticking noise thoughts
nothin like ol' Chevy iron..keep it goin
1948 Chevy Loadmaster Flatbed
Your mechanic friend was right on the moola. Most solid lifters will exhibit some noise, which is piece of mind that they aren't too tight. The fact that the engine is a splash system or pressure system doesn't affect solid lifters.
As I recall, these engines had a tendency to click their wrist-pins. This wasn't fatal either. Enjoy the clicking tappets, it's a sign of distinction. smile
Stuart
Yep, sounds normal.
You should adjust the valves every several thousand miles, and they should always make some noise. No noise = burnt valves.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
The engines with cast iron pistons had a tendency to cluck a little, also. We used to install spring steel "expanders" between the wrist pin bosses and the piston skirt to reduce the clearance a little.
thanks all, its so slight only really hear it if you really listen and have the hood up[... thanks
HRL,
Good ear. You're right..each component had its own unique sound. The wrist pin was a 'cluck', not a tappet 'click' and not a main 'thump'. smile
Stuart
its deff a click from tappets..
