Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
3 members (cmayna, baldeagle, Hotrod Lincoln), 47 guests, and 3 robots.
Topics128,006
Posts1,055,268
Members48,418
#802823 12/02/2011 6:26 AM
doing some rust repair, the 3 vertical ribs on the back of the cab found some old gunk on the back side of each rib, I was wondering if that is some kind of adhesive so the back sheetmetal sticks to the rib, any help would appreciated
thanks James
41 chev #803012 12/03/2011 2:05 AM
I had similar adhesive/caulk there also. Mine was more of a 60 year old dried up piece of rubber. Unknown reason/name/usage. Maybe for vibration
Dan
Chev4t6 #806638 12/14/2011 6:28 AM
did you replace it with anything?
41 chev #809931 12/24/2011 4:10 AM
i had same stuff on my 46.the welds on those strips had broke at the floor so i removed that rubber type material rewelded at the floor then tack welded the strips to the back of the cab
